Question about Sub-Zero 601R
The fridge shows vaccum condenser?
We have a sub zero and it is showing vaccum condenser? I have no idea what this means, any idea?
  • Anonymous Apr 17, 2009
    evaporator icing top left corner, display showing" vacumn condensor" I think refrigerent 134a charge is low. small leak somewhere, but no oil showing anywhere.
    Scholar:
  • 111 Answers
It is just a message advising you to clean the condenser behind the top access panel. Basically an "idiot light" kind of thing although it should be cleaned about once a year
Posted on Dec 20, 2008
How do i shut off and reset sub=zero 690 fridge?
Its not necessary when "Vacuum Condenser" light is blinking means That condenser is dirty. That light will come on if compressor running too long. Most common problem is that Evaporator coil in fresh food section is leaking freon. It still might keep temps ok, but compressor need to run much more to keep temperature you set. check back wall in fresh food section on left side at the middle, behind drawers. if you see moisture in one spot or a little bit of ice build up, then You will need to call people who can replace evaporator. It is pretty expensive fix. I made video how it looks to repair this problem. Thanks.
Feb 21, 2015 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690 model if doors are not flushed right , my fridge door is little out think that is the reason flashing clean the condenser light comes after 12 hrs or so .The fridge is worth 10,000 so how can...
It is perfectly normal for the refr door on a side by side Subzero to stick out a little further than the freezer door. That light could mean several things. If you have vacuumed the condenser then you should call a repairman to look at it.
Oct 19, 2013 | Sub-Zero 690 Side by Side Refrigerator
Code vacuum condensor
clean your condenser coils. located in the top part of the fridge. unplug the unit before service. vaccum the condenser. if after 2 or 3 weeks the vaccum condenser comeback is really posible that you have an evaporator freon leak. in the fridge side
Mar 29, 2010 | Sub-Zero Bottom Freezer Refrigerator
VACUUM CONDENSER MESSAGE KEEPS COMING ON subzero 650. I vaccumed it several times! The temp gauge is showing 48, yet the tem is set on 38
you need to turn off main power to frig...wait 5 mins..plug back in...if does it again replace sensor by condnser coil you cleaned..please ,on the side you cleaned flash a bright light thur it if you see no light, its plugged...then take compressed air an blow thur it...will be a little dust...vaccum up...hope it will help...michael,doctor airr appl.repair..843-384-8474...call if need more assistance..good luck...
Mar 26, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero PRO48 fridge - Error Code 40 and EC91
Here are the most common Sub-Zero error codes:
Sub-Zero Error Code EC40: Freezer will not stop running
Sub-Zero Error Code EC50: Refrigerator runs too much
Sub-Zero Error Code EC24: Defroster is not heating enough
Sub-Zero Error Code EC 06: Evaporator thermistor reads inconsistent temperatures
Sub-Zero Error Code EC20: Defrost Bi-Metal Operation is faulty
Larry Rogers
http://sparkleappliance.com/ca/sub-zero-refrigerator-repair-los-angeles
Nov 08, 2009 | Sub-Zero PRO 48 Side by Side Refrigerator
Sub zero wine cooler showing 78 and76 and says
Clean the condenser located under the unit. This may help. However, more serious problems involve refrigeration leaks shorted thermistors and non running fan motors. All are common. I recommend an authorized Subzero tech for this unit if cleaning the condenser does not help.
Sep 14, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Mar 27, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Sub zero freezer too warm
I believe the freezer has to get down to 7 degrees or lower for icemaker to harvest. Clean your condenser and blow it out. If that doe not fix it you will need service for sealed system
Apr 15, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
266 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
