Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
Two sides of freezer very hot to the touch
Each side of freezer, which is on top, are burning hot to the touch. I only noticed this three days ago, and it cooled down twice for a short period of time in those three days. Does anyone else have this problem, and if so, did you find a solution? Thank you.
    Genius:
  • 2,920 Answers
It sounds like the compressor is going bad or has gone bad
Posted on Dec 20, 2008
Freezer too warm, and i feel heat on the door seals
The door seals warm is from the mullion heater that minimizes moisture from forming in that area, under working conditions. You need to provide more information.... What did you see that made you defrost it 3 weeks ago..
Nov 27, 2013 | Kenmore 53542 / 53544 Side by Side...
We have recently noticed that the part of the refrigerator that separates the freezer from the refrigerator is very hot to the touch on the Samsung RS2630WW Side by Side Refrigerator. It also seems hot on...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 09, 2010 | Samsung RS2630WW Side by Side Refrigerator
Sides and top hot to the touch
dear sir/madam'
i think its low gas problem so kindly contect to your sevice technician for refill refrigerent gas and also change freezer,s door seal ,
thank you
hope answer the question
please vote!
Jul 30, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
2006 chrysler pacifica-wheel hubs burning hot
The problem might have already been there,the steel wheels are making it noticeable,because they don`t cool down as quick.Most likely is the calipers sticking,or you have a set of high dollar brake pads on the vehicle,and they are heating the rotors up.The high dollar pads are a very hard composite pad witch produce a lot of friction,and heat as a sort of side affect.
Oct 23, 2009 | 2006 Chrysler Pacifica
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
GE GSS20IEPAWW Freezer Not cold outside of freezer very HOT
check to make sure that the fan in the back is working and then clean the condenser coil underneith the frig
Apr 26, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Exterior side walls VERY hot
Hi wjjlaw,
ngafm at your service,
Is the hot side th open side or against the wall or cabinet side?
Have you touched this side before in he two years you have this appliance? Or is it that you just noticed it?
And if you can keep your hand on that spot for a long time it is not so hot only warm? If it is not burning your had it is probably just the characteristic of that fridge!
Check if the freezer part is full to the top and packed full.
Freezers can not be so full that you cover the cold air vents usually found in th rear of the freezer.
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
Please give me a good rating before you sign off.
Thank you.
Sep 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Fridge HOT to touch. Hot air coming from back of GE Side by Side stainless steel
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way
Jul 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Side by Side Refridgerator
If the mullion heater around the doors is hot to the touch the inside temperatures are not being maintained. They should be warm but not hot. This usually indicates a problem in the internal temperatures. Check the back wall of the freezer section for frost buildup. Your defrost system may not be working and it had not gotten to the point of complete failure as far as you noticing the temperature differences yet.
Jun 15, 2008 | Whirlpool ED2FHSS Side by Side...
Freezer is running constantly and sides and top are hot.
first whirlpool makes a good product as far as the sides being hot good sign the condensing coils are in the sides are supposed to be hot worry if its running and they are cold then not working right ok as far as running modern units useing 134a do have long run times but are not using but same enegry as 100watt light bulb otay
Dec 30, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
