Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Toshiba 46 in with hour glass picture
The picture has just started moving in from each side like there is a belt pulling tight
  • 233 Answers
The picture has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps!
Posted on Dec 21, 2008
2003 kia sorento sunroof jammed
spray WD40 on it, and try to work it into the mechanism with a toothbrush. This is a solvent and a lubricant, it may loosen it up by melting any dirt stuck in there. After an hour wiggle all the moving parts and see it loosens up and can move ok.
Dec 20, 2013 | 2003 Kia Sorento
2008 46" Toshiba Regza, has bad picture when cold
It would help to see a pic or video. The fact that hitting the top side clears up the picture leads me to believe that you may have a bad LCD panel tab. If this is the case, the only true fix is to replace the screen, BIG $$$
Nov 25, 2012 | Toshiba 46XV540U 46 in. LCD HDTV
How do you get the deck belt back on the pulleys? 20 hp-46'' deck
It helps to remove the belt gaurd on the left side of the deck. The belt gaurd on the drive pulley ( motor crank) can be pulled out and moved by hand- lay on left side of mower and reach across and pull right side of belt gaurd from hole in frame and swivel away. Once belt is installed slide gaurd back into hole. all other pulleys the belt can just be spun on past the gaurds. Be sure to replace all belt gaurds and saftey devices as they came from the factory.
Nov 24, 2009 | Mtd Garden
Need a picture to no how the belt goes on
I have put belts on many vehicles, and if you have purchased the right one it should explain itself with some concentration. Most belts have a ribbed side and a smooth side. if the pully wheel is meant to accept the ribbed side it will also be ribbed. If it is meant to accept the smooth side it will be smooth (possibley with a ridge on each side to keep it centered) Just start by putting the ridges side on one pully and move the belt around each successive pully until you are left with the alternator as the last one. Usually the alternator is the one piece that can be adjusted in so that you can get the belt on and then moved back out for tightness.
Apr 23, 2009 | Chevrolet G20 Cars & Trucks
Loud ratchet noise
Have you been using ink cartridges other than store bought? Reason I'm asking is that i used a refill kit, and tried those half price refill places, only to find ink was leaking out when not in use & clogged up the ends where the cartridge moves across. take a flashlight & look at the ends of the track that the cartridges slide across on, you may see a build up of ink, that won't allow the cartridge to travel as far as it needs to go to run properly.
Nov 06, 2008 | HP LaserJet 3330 All-In-One Printer
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Green Solid Hour Glass
possible convergence amp ic's failed should be under $300.
Sep 05, 2007 | Toshiba 46H84 46" Rear Projection...
Zenith 46" with a "hour-glass" picture.
If the hour glass figure is a seperation of colors that appear to be convegence mis aligned, then, the convergence ICs would be the problem. If the picture is clear and you have a bending on the sides then the pincusion circuit in the horizontal circuit is where to look. Be careful of this circuit, it does control the high voltage. The only way to have a board checked is to have an Authorized Service Center look at it. It does, however, sound like there is a cold solder joint in the power supply that has gradually opened up and now is permanantly open. Call Zenith (LG) to see who they recommend.
Mar 25, 2007 | Zenith Z46Z83D 46" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
