Question about Epson PictureMate InkJet Photo Printer
Leopard i' m o n tiger, not leopard
  • 2 more comments
  • pmollica Dec 20, 2008
    intel core 2 duo
    didn't work.  printer can not find driver under: Print using...
    the name does NOT appear
    the one thing i did NOT do was reset the printer. i'm not willing to reconfigure all the printers I've got set up. i know there will be a problem when i go to do reconfigure them, so i'm not going to delete them.
    this should work without my having to reset the printer utility.
    its a plain old pictureMate, no other model number. i have picked the correct download for intel- based, v.3.0aas.  i just downloaded the printer driver on another persons mac (leopard) and it found the driver immediately. but it does not find it on my computer. the printer worked fine on the other computer, so its not a hardware problem, just this driver issue
  • pmollica Dec 21, 2008
    I did everything you told me to do, including resetting the print utiltiy and it still does NOT see the printer driver! its still asking me to choose one, rather than automatically selecting the driver i just downloaded - i'm about to get rid of this printer, its not worth all the time i'm putting into this! it just plain does not work. thanks for your help but this printer is going in the trash, its taken up my entire day trying to solve this
  • Epson Master
  • 1,879 Answers
Is your picmate a zoom, express, deluxe or dash ?
Posted on Dec 20, 2008
  • 6 more comments
  • monk3ybidzness
    monk3ybidzness Dec 20, 2008
    also is your mac an Intel or PowerPC (click apple then about this mac)
  • monk3ybidzness
    nice, one more thing - look under the picmate
    unit model starts with PM
    here's the step for PictureMate Deluxe (Tiger on Intel) remove, download, install
    Please follow the steps below to completely remove and reinstall a downloaded driver for your printer in OSX.4
    DEVICE REMOVAL
    1. Open the MAC HARD DRIVE, APPLICATIONS folder, UTILITIES folder, PRINTER SETUP UTILITY.
    2. Highlight any listings of the Epson drivers and select DELETE.
    3. Close the PRINTER SETUP UTILITY.
    REMOVE FILES
    1. Double click on the MAC HARD DRIVE.
    2. Double click on the LIBRARY folder.
    3. Double click on the PRINTERS folder.
    4. Drag the EPSON folder to the trash can.
    *NOTE* If you receive an access denied error message, this indicates that you do not have root access. You will need to contact Apple for assistance on obtaining Root Access.
    5. Close any open windows.
    6. Double click on the MAC HARD DRIVE.
    7. Double click on the LIBRARY folder.
    8. Double click on the RECEIPTS folder.
    9. Delete any Epson Receipts.
    10. Close all windows that are open, and restart your computer.
    NOTE: The following procedure will remove all printers that you have installed on your computer. If you have multiple printers on your system, you will need to re-add all your printers once this is complete.
    1. Make sure that your printer is turned on and connected to your computer.
    2. Open the HARD DRIVE, go into the APPLICATIONS, and select the UTILITIES folder.
    3. Double click on the PRINTER SETUP UTILITY. Click on the PRINTER SETUP UTILITY Menu option at the top of the screen and click on RESET PRINTING SYSTEM. Click on RESET when prompted and then enter your system password. This will remove all printer drivers in the list and you will have to add all of them again. Now download the current printer driver.
    DOWNLOAD
    Please follow the steps below to download and install your printer in OS X:
    1. Go to the websitehttp://support.epson.com
    2. Under the PRINTERS heading select Ink Jets and then your printer model.
    3. Under the Drivers & Downloads section select Macintosh. Download the most current version of the Printer Driver for your Macintosh operating system.
    INSTALLATION
    1. After download is complete, double click the icon that appears on your desktop, then click CONTINUE, then CONTINUE again, then OK on the INSTALLATION WAS SUCCESSFUL screen.
    2. Open the new folder created by the extraction process. It will appear something like epson1XXXX (X represents variable numbers).
    3. When you open this folder, you will find a file with a .DMG extension - double-click it. This will create another icon on the desktop with the name of your printer. Double-click to open the DISK IMAGE file.
    NOTE: In most OS 10.3 systems the installer will perform this step automatically and you will see an INSTALLER.PKG file.
    4. Double click the INSTALLER.PKG file to start the installation process.
    5. The next menu will prompt you to ensure that you have Administrator Rights to install the printer driver. Click on the lock (if necessary) and enter your password.
    6. The actual installation process will begin. Click CONTINUE, then CONTINUE again at the SOFTWARE AGREEMENT window, then CONTINUE again, then AGREE.
    7. You will be prompted to select a disk to install the printer to. Select the appropriate Macintosh HD or OS X drive or partition and click CONTINUE.
    8. In the next window that appears, click INSTALL.
    9. You may be informed that the computer needs to be restarted after installation; click CONTINUE INSTALLATION here. The driver will now be installed and the system optimized. Restart the computer when install is complete.
    Configuration
    3. Double click on the PRINTER SETUP UTILITY. If your printer is listed correctly, close out of the windows and test your printer, as it is already installed.
    4. Click the Add tab at the top of the Printer Browser window and then select More Printers tab at the bottom of the Printer Browser window and then select Epson USB and then select your printer under Product Name. If applicable select the arrow by the Standard option under the Page Setup option and select the All option. If not simply click on ADD.
    5. Close out of any open windows and test your printer. Please make sure that you select the correct printer in the page setup and print menu of the application.
    if the above does not work - post back the exact model :)
  • monk3ybidzness
    repeat the trashing part - this part is really hard (spending a minimum of 30 minutes on the phone with it)
    then reboot the mac twice, check for the folders & files before installing again.
    TRASHING PART :)
    DEVICE REMOVAL
    REMOVE FILES
    *NOTE*
    NOTE:
    complete.
    3.
    printer driver.
  • monk3ybidzness
    about the printer model - very important - look under or the sides - there are 4 models of the picturemate, and we need to get the specific driver
  • monk3ybidzness
    monk3ybidzness Dec 21, 2008
    the RESET PRINTING SYSTEM will only delete all registered printers in the PRINTER SETUP UTILITY but will never delete the installed drivers. You just have to add the other printers again after reboot (printers must be connected and turned on).
    Trashing the EPSON folder will delete the driver installed.
    the RESET PRINTING SYSTEM part is a must - verified it with both EPSON and Apple as I was looking for other ways to fix this issue.
  • monk3ybidzness
    this is the driver you have right ?
    Printer Driver v3.0aAs
    Intel-based Macs with OS X (v10.4.4 - 10.4.x)
    epson11846.dmg - 5.2MB - posted on 06/06/06
    This file contains the Epson PictureMate Printer Driver v3.0aAs for Intel-based Macintosh computers with OS X (v10.4.4 or later).
  • monk3ybidzness
    more from the download page
    1. Installation instructions: Double-clicking this file creates an "epson11846_mate_printer_driver_30aas" disk image on your desktop.
    2. Open the disk image.
    3. View the included "Readme First.pdf" document for important information.
    4. Double-click the "PictureMate 30a" installer icon to begin the installation.
    Important pre-installation instructions:The Macintosh OS X driver found on the CD provided with your product is not intended for use with Intel-based Macintosh computers. If you have already installed the OS X printer driver provided on your product CD, please follow these important instructions before installing the "epson11846.dmg" file:
    1. Open the OS X "Printer Setup Utility".
    2. Select the "Printer Setup Utility" tab and click "Reset Printing System...".
    3. Click the "Reset" button.
    4. Restart your computer.
    5. Install the downloaded "epson11846.dmg" file.
    Reset Printing System really is needed.
  • monk3ybidzness
    link to epson11846.dmg driver
    hitting the sack 8 am here - just post back here
    Reset Printing System ? c'mon give it a try :)
Upgrade for a 2005 apple mac desktop tiger 10.4
The highest you can get up to is leopard 10.5. Unfortunately, after 10.5 Apple moved to Intel getting rid of the powermac processors.
Depending on your specs I would recommend sticking with tiger, but leopard should run fin on your powermac. It runs great on mine.
Jul 22, 2013 | Apple Power Mac G5 Desktop
Comparision Tiger skulls to leopard skulls
I'm sorry, but this is not a website question. Please ask the same question in a different category.
Jul 02, 2013 | Computers & Internet
Animal skeletons
This link has information and images of what a Siberian tiger's skeleton looks like.
Siberian Tiger
And this link will have the same information and photos of a leopard's skeleton/skull.
Leopard
Jun 28, 2013 | Computers & Internet
Apple mac osx 10.4 tiger
you need system disk. cannot upgrade across os platforms without disc.
Apr 09, 2013 | Apple Mac OS X 10.4 Tiger for Mac
Can a iMac G5 A1207 use tiger OSX 10.4.11 to boot up or do I need Leapard 10.5
I wouldnt see why not just read the specifications before the install
May 06, 2011 | Computers & Internet
I only get a black sheet of paper if I copy with my hp 1610
you will need to download the driver for leopard after you remove tiger
Aug 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp laserjet won't print under leopard.
Have you updated to the latest driver, I'm not sure the original driver for "tiger" would necessarily work with "leopard". There is an updated universal driver for all OS X versions.
Just a suggestion.
You can get it here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14991&prodTypeId=18972&prodSeriesId=25478&swLang=8&taskId=135&swEnvOID=219
Jun 16, 2009 | Xerox Phaser 8200 Laser Printer
Cannot boot Leopard or Tiger
Can you pleasr post more information on when how this was started I had this problem once with bootcamp but now it was resolved. Can you still get in somewhere?
Jan 03, 2009 | Apple ATI RADEON 9600 XT for Macintosh G5...
Mac OS 10.5 Leopard
two issues here..
compatibility of Epson with Leopard..and also the drivers will need to be postscript compatible..not an easy task.
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Epson Stylus R380 InkJet Photo Printer
Epson PictureMate InkJet Photo Printer Logo
155 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
