Question about Measuring Tools & Sensors
Need instruction for a 17 ft. cosco ladder
Just bought a 17 ft ladder and the instructions are all oren into pieces. would like to have another set of indtructions if at all possible. thank you.
  • 3 Answers
Try going on-line to the manufacturers web site if there is one. More to the point is what is it you want to do that you can't with the ladder?
Posted on Jan 16, 2009
Couldn't be any easier all changes to the ladder can be made by pulling the pins just below the hinge Straighten the ladder out flat for an extension ladder To use as a scaffold you will need two ladders
Posted on Apr 14, 2014
Tip
Building your own ladder golf set
Building your own set for ladder golf is relatively easy and shouldn't take you too long. So you can be up and running in just a few hours.
You are going to need is 1" PVC pipe cut into 6 12-inch pieces and 9 24-inch pieces. You are also going to need 6 elbow fitting, 6 t-fittings. For the balls you are going to need 24 solid golf balls (2 sets of 12 in 2 different colors) and about 28 feet of nylon rope.
To building the ladder to form the base take 4 of the elbow fittings and two t-fitting and the 6 24-inch pipes. Connect the pipes to the elbows and the T's so that they flat side of the T is facing down. There should be an empty socket facing up. When you are finished you should have a rectangle that is 4ft by 2ft with 2 upward facing sockets to hold the ladder.
Next you want to build the ladder. Start by taking one of the remaining 24-inch pipes and attaching an elbow fitting to each end. Then attach a 12-inch pipe to the other side of the elbow. At the other end of the 12 inch pipe you are going to attach a t-fitting, continuing along the plane of the 12-inch pipes attach 2 more 12-inch pipes and in the cross plane attach a 24-inch pipe. Repeat this for the bottom step of the ladder. After you have attached the last pipe fit the open ends into the base and there you have your three step ladder for playing.
To make the balls you are going to need a drill to drill a hole through the center of the 24 balls. After you have drilled the holes in the balls take your nylon rope and measure and cut it into 12 20-inch pieces. It is suggested that you burn the ends of the rope so that they don't fray. Stick the rope through the holes and tie a knot on either side of the ball so they don't move. Put one ball on each end of the rope. You are going to need 6 ropes with 2 balls on each.
Once you have finished making the balls you are ready to play! Some play with each player on their own ladder, if you want to play that way you can follow these instructions again to build a second ladder or you can just use one.
on Oct 28, 2013 | Sport & Outdoor - Others
Hub nut tension question from before.
Sam, 2003 Ford E-150 v-6 front axle nut torque, It is not just a matter of torquing the nut as seen in a lot of videos, where they do install by feel. There is an actual procedure to ensure bearing seats correctly so it will last when properly lubed and installed. Below is the 5 step procedure from SKF pdf.
Tighten hub nut to 30 ft-lbs/40 Nm while spinning/ turning wheel. Back off 2 turns. While rotating brake disc, tighten to 17- 24 ft-lbs/22-34 Nm. Loosen nut 175 degrees. Tighten nut to 17 in-lbs/2 Nm.
Check the attached link instruction and guide, Good luck. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.skf.com/binary/79-66360/457377.pdf
Jul 21, 2016 | Cars & Trucks
What is ladder golf?
Ladder golf is a tossing game played with a ladder placed about 15 feet from the player, and three sets of bolas (two golf balls connected by a string). The player has to toss the bolas to the ladder trying to get them hanging by the string to the ladder bar.
Here is a basic instructions video:
http://www.youtube.com/watch?v=sK6qBkBmF3U
Sep 24, 2013 | Sport & Outdoor - Others
I bought used mpc4500. Counter counts 2 clicks for 11 x 17 copy. Ricoh service tells me there is no way to reverse that setting back to just one click per 11 x 17. Is this true?
doubtful its true,but it is a standard practice to set up the machine to count 11 by 17 as 2 clicks because it is 2 pieces of 8.5 by 11 which are counted as 1 .... GET IT ?
Jan 25, 2013 | Office Equipment & Supplies
Just bought this freezer the door won't open -any ideas why -thanks? David
Most upright freezers that I know of have a lock on the door. If there is a tiny hole 1/4" or less in the front surface of the door that has a chrome ring around it, It is a lock mechanism. Look in the envelope that includes your instructions, there may be a key in it. It may have been locked for shipping.
The other possibility is that there is a piece of some very strong fiber impregnated shipping tape strategically located so that it is difficult to see, keeping it closed.
Hope this helps,
Best Regards,
Mark
Jan 07, 2011 | Frigidaire 8.7 cu. ft. Upright Freezer...
Measuring Tools & Sensors Logo
1,467 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
