Question about Sharp AL-1641CS Laser Digital Copier
Status light still on!
We have a Panasonic DP C354, which required the Cyan drum unit to be replaced, which it was and the status light did not reset it self, is there some where we can go to reset this?
  • dcannon898 May 11, 2010
    Have you tried doing a manual quality adjustment, from the control panel? If not, this will sometimes, not always, reset the status light.
    An expert whose answer gotĀ voted for 100 times.
  • 126 Answers
Go into your User tools / customer tools, machine ( management) and look for the calibrate / or replace. Select the proper color and follow. If you had a Tech replace you may need them to go into the Tech mode and reset the code. If you paid to have them come out to replace, this should be covered in the cost.
Posted on Jan 05, 2009
On a panasonic dp-c354 is there a way to wash the waste toner container
you can dump these then blow them out with air but if they become to aged it is just best to replace the waste container
May 06, 2014 | Panasonic DP-C354 Copier
Replace drum unit cyan
open the front door, remove the waste container & replace the cyan drum with a new UHN30 color drum (these drums work for all the colors on this)
Apr 08, 2014 | Panasonic WORKiO DP-C262 Printer
Panasonic D-P C354 error code E04-14
try function, original size keys and number 3. Function should appear
Mar 19, 2012 | Panasonic DP-C354 Copier
I have error code E03-30 on panasonic DP C354,how i can fix and reset?
You most likely have a bad feed motor. It's located mid right rear behind big PC board and mounting plate. It's a job for a technician.
Jun 23, 2011 | Panasonic DP-C354 Copier
1. Press the "Function", "Copy", and "3" keys simultaneously in that order to enter the Service Mode.
2. “Input the password” to enter the Service Mode (default password is 00000000, except for C322/
C262 which do not require a password).
3. Press "7", and then “Start” keys to enter the F7 Service Mode (counter ).
4. Check the entry for the option 01 that will be you password
Jun 19, 2010 | Panasonic DP-C354 Copier
Can i change the DQ-UHS30 drum unit into DP-C354 copier myself or do i need a technician to do this
Most Likely a Tech.
Order your drum unit from then look at it to see if you can do it yourself. I'm a Canon guy but I think that on this machine it's not to bad. Open your front door on the machine and look it over. There may be some plugs to unplug etc.
Jun 09, 2010 | Panasonic DP-C354 Copier
Panasonic DP-8020P Machine Maintenance count reached.
yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
Nov 02, 2009 | Panasonic DP-8020E Black and White Copier
How do I cancel a print job - Panasonic DP-C354?
Go to controll panel touch the print button on the left bottom, touch print queue, it will ask for password which is 8 zeros. touch print job and hit cancel
Sep 27, 2009 | Panasonic DP-C354 Copier
Mac Drivers
you need to have a PS [post script] key installed in the machine before you can do anything
Jun 13, 2008 | Panasonic DP-C354 Copier
Sharp AL-1641CS Laser Digital Copier Logo
48 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
