Question about Cyberhome CH-DVD 300 DVD Player
Cannot change region code on my Cyberhome ch400
I FOLLOW THE TERMS BELOW BUT WHEN I GET TO VERSION AND PRESS ENTER IT DOES NOT COME UP WITH REGION
Cyberhome CH-DVD 400 / CH-DVD 402 / CH-DVD 405 / Prism DV-302 / Prism DV-402
  1. Turn on the player
  2. Open the disc tray
  3. Press SETUP
  4. Press 1, 3, 6, 9
  5. Press LEFT, LEFT, LEFT, RIGHT
  6. A new menu entry appears
  7. Select "Version", press ENTER
  8. Select region
  9. Exit menu
SOURCE: Can get to region unlock menu but refuses to change.
hi try this one there are 2 versions they both have different chips.
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
it worked for me.
Posted on Feb 26, 2008
Bubbabear64
  • 2794 Answers
SOURCE: the cyberhome no picture when playing a dvd on the ch-ldv 712
Sometimes portable DVD players allow you to switch to a secondary TV for playback. When this happens it disables the primary screen on the portable DVD player.
Thats usually the culprit as to why that happens.
If you have that feature on your portable DVD player you should check it out.
Posted on Jun 14, 2008
SOURCE: Need remote codes
How about Sony remote codes?
Posted on Sep 09, 2008
I have DirecTV and I have the same remote and I read somewhere you can use the codes for Sampo. I found the codes in the DirecTV remote's manual. The first one I used worked. Hope this helps!
Posted on Jan 01, 2009
SOURCE: disassemble CYBERHOME DVD CH 300
This guy has pictures and instructions for a major operation on a cyberhome player.
http://backandforthblog.com/?p=11
Posted on Mar 12, 2009
I have a Cyberhome CH DVD 300 (region 1), I want to change the region on this player. I learned I need for first: 1.- Turn On the DVD player 2.- The tray needs to be closed and empty 3.- Press the Menu...
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
Dec 07, 2010 | Cyberhome CH-DVD 300 DVD Player
Tip
Cyberhome AD-N212 Region Free Fix Would you like to unlock your Cyberhome...
Would you like to unlock your Cyberhome AD-N212 DVD player to Region Free?
Follow these steps to unlock your Cyberhome AD-N212 DVD player:
  1. Open the drive tray
  2. Press the 7 button on your remote control
  3. Press the 6 button on your remote control
  4. Press the SEL button on your remote control
  5. You will now enter the hidden setup page
  6. Change the player toany Region or set it to Region Free by entering 13 as the country code.
Your Cyberhome AD-N212 DVD player is now Region Free.
I hope that helps.
on Apr 25, 2010 | Televison & Video
Is it possible to change the region code to region 3 so we can watch movies from Thailand? No need to switch back as I have another DVD on region 1. Charlie (cleggett1937@aol.com)
You can make this player REGION FREE so all discs operate on it.
Power up, no disk in. Status says READ then INSERT DISC.
Press MENU (status reads invalid key icon)
Press 1 (status reads invalid key icon)
Press 9 Menu is displayed.
Press ENTER on the region, digit turns to "-"
Press 0
Press ENTER again
Press EJECT to clear the special menu.
If you reset (unplug) the player for any reason - this will need to be re-entered.
Thanks for using FixYa!!
Mar 18, 2010 | Cyberhome CH-DVD 300 DVD Player
Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
Sep 11, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Need remote code
try this method THIS METHOD WORKS FOR THE CH-DVD 300, CH-DVD 300S, AND CH-DVD 320
1. Switch player on, making sure that there's no disc in the tray.
2. Close tray.
3. Using the remote control, key in the following: MENU, 1, 9.
4. A menu will appear with the region option near the bottom of the screen.
5. Press ENTER, enter the desired region (0=REGION FREE )AND PRESS ENTER again to save the desired region.
6. Press OPEN/CLOSE. Hope this helps you with your problem
May 02, 2009 | Cyberhome CH-DVD 300 DVD Player
Unlocking the LG HT303su DVD from region2 to region 0
Hi, I could not get it to work using the other ways, Also I am not sure if this might help I am in Australia region 4 and the below worked for me
(1) Make sure there's no disc in the system and turn it off. Turn the system on again and it will display a "no disc" message on your TV.
(2) Use the remote control: press the "PAUSE" button and then key in the code "314159"
(3) Your TV then displays a menu for choosing the desired region. Select "0" to make your unit an all region player.
(4) Press the "PAUSE" button again.
(5) Turn the system off and wait a few moments before restarting.
Mar 06, 2009 | Televison & Video
Cyberhome dvd player ch-dvd 300 What region code is this dvd player? can it play region 2 dvd's?
Dear friend,
Try this method to change the region.
2. Close tray.
5. Press ENTER, enter the desired region AND PRESS ENTER again to save the desired region.
6. Next press OPEN / CLOSE.
Nov 18, 2008 | Cyberhome Televison & Video
  10. Exit the menu
it worked for me.
Sep 24, 2007 | Cyberhome DVR 1600 DVD Recorder
Region Error
this is for: Cyberhome CH-DVD-300 1. Ensure the players disk tray is Closed with no disc . 2. Press Menu. 3. Press 1. 4. Press 9. 5. A menu will appear with the region number near the bottom of the screen. 6. Press Enter. 7. Select the desired region. 8. Press Enter to save the settings.
Jan 31, 2007 | Cyberhome CH-DVD 300 DVD Player
Multi region for CH DVD 300
There's a tricky process to follow with the remote control to set the region code. It is: -Open the player. -Remove any DVD. -Close the player. -Power off the player. -Wait for 30+ seconds -Power on the player. -Press Menu,1,9 on the remote [this frequently takes a few tries]. -When the region screen appears, press enter to change region (Every time you press enter, the region code on the screen will increment by 1). -When the proper region code is displayed, press Return. -Open the player. -Insert DVD. -Close the player. -(Maybe just my player) If the player doesn't start the DVD, repeat Open/Close until the DVD starts. If it still doesn't start, power off for 10 minutes. Good Luck!
Jan 21, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
43 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
