Question about Navy Seal Luminox Dive Watch
I need the crystal the watch - Navy Seal Luminox Dive Watch
  • 2,338 Answers
Take the watch to your nearest watchmaker and ask for replacement. There is no problems with replacement glasses in watch repair industry.
Posted on Dec 21, 2008
How can I changw the glass for this watch?
In order to replace the crystal on your watch you are going to have to remove the entire movement and use a watch press to remove the crystal.
this is not an easy job and should be done by a professional
First you will need to get a watch back opener to unscrew the back of your Tag. The three slots should fit into the back of the watch. tighten the opener until it is firmly on. then turn counter close wise until back of case comes off.
Next you will need to remove the watch hand and crown. Becareful doing this for pressing to hard will break your set leveler. You will need a thin pin pusher and look on the back of the movement for an arrow pointing toward a hole in the movement. Push down and at the same time pull the stem and crown out of movement. turn the watch right side up and the watch movement should fall out. Place movement on a very safe spot so not to damage movement or dial
now you will you be ready to remove crystal Since it is a friction crystal you will need to do use a watch case press . find two die that fit exactly the watch and crystal use a scooped side and place it on the bottom side of the watch press. Next use a flat die to place on top of the case press. place the watch face down. you will be pushing the watch crystal out from the top. Press down on the level and check to see if the crystal came loose, keep doing so till the crystal comes out.
finally you will need to measure the thickness and diameter of the crystal and find the exact size. I believe this watch has a sapphire crystal so you will need a sapphire crystal too.
Once you buy the proper crystal it is time to put the it in the watch. Place the watch face up in your watch press. and slip the crystal in through the top making sure its perfectly even all around. Slowly push down on the leveler until proper pressure is applied and the crystal snaps in.
Now you have new crystal . Clean crystal thoroughly and the inside of the case. Place watch upside down carefully place movement back in. slide spacer in . Now slide watch stem and crown back in push down again on the set leveler with pin pusher.
Place case cover on back and tighten properly to prevent water or moisture from entering and you are done.
This repair should be done by a professional especially on such a nice watch. Any watchmaker can do this job and will have the tools to do it properly
Jan 27, 2012 | Tag Heuer Carrera GMT WV2113.FC6169 Wrist...
The crystal of my wife's skagen watch popped out and the nylon ring surrounding the crystal seems too big to get back in, or perhaps I just don't have the right tools. Help!
Watch crystals are pressure fitted to their cases so that they are resistant to popping out. Think of a champagne cork, and how it expands when it comes out of its bottle.
Crystals are set into cases in one of several basic methods. First, a crystal may be installed from the back--watch cases are commonly assembled before the movement is installed. So, one potential way of reinstalling your crystal is to remove the watch movement from the case (if it isn't already) and try pushing the crystal from the back forwards. If this is indeed the way it was installed, the crystal should pop into position with a noticeable click or light thump to let you know that the other edge of the crystal has found the shallow groove in which it's supposed to sit.
Second, some crystals can be installed from the front using a tool called a "crystal lift." This tool has many little fingers that compress the edge of the watch crystal so that it can be slid into the case. Pressure is then gradually removed from the crystal, permitting it to expand into the shallow groove into which it's supposed to sit. Crystal lifts are easy to use in theory but somewhat finicky in real life; the crystal must be grabbed equally by all the lift prongs or else the crystal will have a tendency to squirt out of the tool before it's been completely set.
Looking at pictures of your wife's watch, it doesn't look to me like a crystal lift would do any good. I think instead that your crystal might have been installed using a third method. Looking at the pictures, it looks like the bezel--the metal top of the watch--separates from the watch body. If this is the case, gently pop off the bezel and push the crystal into it from behind. Then, push the bezel back onto the watch movement. It's possible that the crystal is kept in place by being squeezed between the bezel and the rest of the watch case.
If all of this sounds daunting, putting the crystal back in--assuming it's not cracked--is a minor job for a watch repair technician. It literally might only take 5-10 minutes to complete the job. If you're concerned about the appearance of the watch, it might be safest to pay someone the small amount of money to get this done right. Replacing a watch crystal with a new one usually runs about $15-25, around where I live. Replacing an undamaged crystal that's popped out should cost appreciably less, since a new crystal costs a jeweler between $5-25 for most standard sizes (diver's watches and strange specialty shapes will cost more).
May 16, 2011 | Skagen 358SSSD Wristwatch
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    I bumped and chipped the crystal. Is it possible to have a new crystal sent to me?
    mcdevito75 here, That may depend on the watch and the maker of your watch, as sometimes a new crystal is only available thru the watch manufacturer, if so, the watch manufacturer may want to install the new crystal themselves. If your crystal is made by an after market company then yes you could get a new crystal sent to you. Look for a small watch repair shop in your area to find out for sure.
    Aug 11, 2010 | Beverly Hills Polo Club Dress #52012 Watch...
    I need to find someone who can make a crystal
    If your watch crystal is round, there is no need to hand made it. Visit your nearest watch repair shop and ask to order one. Rate me , plz.
    Mar 26, 2010 | Chaika Appointment (amazon-stone)' Ladies...
    My watch has a chip in the crystal - who can put a
    Chip in crystal is not repairable. You need a new crystal. No need to send the watch away, as any local watch repair shop can do this.
    Rate me, plz.
    Jan 13, 2010 | Timex 27191 Wristwatch
    Need a crystal for Geneva ladies watch #7499
    Take it to any watch maker shop who does customize crystal
    and if you are in chicago we do customize crystal
    hope this help
    from
    AmFix Jewelry & Watch Repair
    203 N. LaSalle Street,
    Chicago, IL 60601
    Ph: 312 641 7000
    Email: info@goamfix.com
    Web: www.goamfix.com
    Sep 24, 2009 | Geneve Watches
    Crystals framing my Haurex watch face are falling out.
    Hi, im a jeweller myself. The problem with jewellers and crystals is simple. Its a lot of work to replace something that doesnt cost a lot to buy (the crystals, not the watch). Swarovski are a commonly known producer of crystals, but you will probably find that simulation gemstones such as Cubic Zirconia are commonly used in newer watches.
    I specialise in gemstone setting, and can also work with simulation stones and crystals, but it takes much longer to reset stones into a stainless steel watch case than into gold or platinum so the labour costs are much higher.
    It depends how much the watch is worth as to how much you spend on repairs.
    Hope this helps
    Dec 18, 2008 | Haurex 27473-031-00 Wrist Watch
    Need to replace crystal on Luminox 3000
    All types of crystals are available worldwide.
    Visit your nearest watchmaker and he will be able to supply new crystal and fit it.
    Dec 04, 2008 | Luminox Navy Seal Dive 3001 Wrist Watch
    Repair
    We are located in the Holyoke Mall in Holyoke MA. Kenneth Cole crystals can be taken off. The crystal needs to be ordered.
    Apr 10, 2008 | Kenneth Cole KC1104 Wrist Watch
    Navy Seal Luminox  Dive Watch Logo
    143 people viewed this question
    Top Navy Seal Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    deton8 von Splosion
    Jim Weinandt
    Jim Weinandt
    Level 1 Expert
    Are you a Navy Seal Watch Expert? Answer questions, earn points and help others
