Question about JVC AV-48WP30 48" Rear Projection Television
Night or dark scenes are too black
The problem I am having is that the night scenes in TV shows are so black that they actually look almost like a negative in a film. It is digital cable with no HDTV and setting the brightness or any other setting to compensate does not help. The TV is about 3 yrs old but it I have had this "problem" from the beginning.
    Genius:
  • 1,074 Answers
Take your set to a tech for adjustment of the focus.
Posted on Apr 03, 2007
  • John Schuholz Dec 21, 2011
    the solution above is incorrect. This is a fairly simple fix. take the front cover off, remove the black cover with the screws, loosen the crt socket board screws, ane gently remove crt driver boards and re-insert them back and forth a couple of times. then make sure they are on firmly and re-tighten screws. Your set is fixed. re-install front covers. manually re-align set and your ready to relax.
The picture is very dark
Unfortunately, there is no easy fix for this. If it were a rear projection TV, I'd suggest a new bulb. Even on a Plasma there are things that can be done. But on a CRT, the repair for a dark screen usually costs more than replacing it.
Sep 20, 2007 | JVC AV-32F702 32" TV
I have a vizio Vt470m....the picture has always been perfect. All of a sudden when picture shows scenes with very little light (dark scenes like at night, space, low light) the black color almost look
Either the TCON board or the LCD panel has failed. Start by replacing the TCON board. If the problem persists, the panel is bad and the cost to replace it would be too high.
Mar 22, 2014 | Vizio Televison & Video
Night seens are very dark
Call a good TV Tech and have him check all crt anodes for proper connection. Also remove & reinstall all crt boards, clean spark gaps. This TV is also known for having bad convergence amp IC's.
Jul 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
How to increase brightness in Canon Powersot A620 ?
Are you asking about brightness as viewed on the LCD, or are you asking about increasing brightness on the actual image taken? If it's the image, there are two special modes that you can select on your mode dial. They are "Night Scene", "Night Snaphot", and "Indoor". A description of both, along with your camera's other special settings, may be found here:
http://www.canon.co.jp/imaging/mode/camera/scene-e.html
"Night Scene" can be selected directly from the dial. It's the one showing a person standing under a star. Note that Night Scene should be used with a tripod to reduce the potential for blurriness.
"Night Snapshot" works almost as well, but does not require a tripod. It can be accessed by selecting SCN on the dial, and then pressing right or left with the selection buttons until it shows in the menu. The camera will remember this setting the next time you select SCN. I usually keep my camera always set to this setting so that I merely have to select SCN to use it.
"Indoor" works very well in those large rooms that may produce dark backgrounds when taking photos. It also does not require a tripod. It's accessed the same way as "Night Snapshot" (Select SCN, then right/left until selected). This is another good setting that I like to keep sometimes set in SCN.
Try all three settings, (and don't forget all the others too). Think you'll be impressed.
Feb 23, 2008 | Canon PowerShot A620 Digital Camera
JVC TV
u need to adjust contrst settings
Feb 21, 2008 | JVC AV-27D305 27" TV
JVC AV-48WP30 48" Rear Projection Television Logo
121 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
