Question about Zanussi ZWF1440 Front Load Washer
Zanussi TCE 7276 W Tumble dryer Error E60
My tumble dryer door repeatedly pops open. Cool, damp clothing. Showing E60. Any advice please.
  • sweatpeako Dec 21, 2008
    have a zanussi 1217 w washing machine displaying the error code e50, it wont do anything, what does this mean?
gittos73
  • 244 Answers
SOURCE: Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Posted on Aug 15, 2007
  • 249 Answers
SOURCE: Zanussi washer drier 1480W door lock
Zanussi's always keep clicking before starting.I don't know what E60 is about,but I take it the machine is working?
Posted on Dec 13, 2007
SOURCE: E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Posted on Apr 18, 2008
SOURCE: SAMSUNG FRONT LOAD WASHER
samsung machines have a common fault i have a j1253 and this problem has come up also another problem is that the drum over fills with water this fault is caused by a vacumn pipe which has either a blockage for less water or a hole in it when the drum overfills this vacum pipe is located in my washing machine at the front under the top itis a small pipe which is whitish in colour running from the back of the machine at the bottom along the right side of the machine and travel upwards to a round vacum valve this pipe either gets squashed by the movement of the drum and the concrete balance or in the case of over filling rubs and creates a whole check this pipe as this is usually the cause
Posted on Aug 31, 2008
SOURCE: Tumble Dryer
how do i fit felt gasket on front of dryer?
Posted on Nov 15, 2008
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Zanussi Tumble Dryer TCE 7276W error code E50 - what shall I do? I put washing in TD and set it A and turned it on, it came up 2.05 as it always does but after some time, I come across "End" is...
Hello this is Dennis from blue hawk electronics I had the same problem with my Zanussi tumble dryer and all I did was to take out he front circuit board and reflow board and has been working fine now for 9 months and still going strong
Sep 03, 2011 | Dryers
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
May 08, 2011 | Dryers
Tce 7276 tumbledryer error code E60 keeps coming on then the door opens what does this mean
Sorry I dont know the answer but maybe a quick call to Zanusi service department can advise what that means.
Feb 05, 2011 | Washing Machines
Zanussi TCE 7276 W Condensing Dryer
hi i have a problem with the zanussi 7276w model all lights are on ready to start but the tumble dryer will not start
Sep 21, 2008 | Zanussi TC7114W Electric Dryer
We have a zanussi TC470 tumble dryer, it heats up at first but once we have left the clothes to dry for 70mins, we find that the clothes are still wet & the door has opened on the machine. Can...
The fixed thermostat on the Heater is probbaly faulty. (not the one with the reset button) I believe it is a Normall closed 80degree thermostat. What happens is they open when they get too hot and reset when they cool down. Probably broken. Worth replacing. Could be the one with the reset butti=on but as thye need a manual rest, probably not.
Aug 05, 2008 | Dryers
Tumble dryer fault
usually this is a sign the felt bearings on the drum, or the roller bearings under the drum are worn and need replacing
felts and rollers should be visible once you open the case
check the rollers turn freely, check the felts are not worn through
replace both rollers or both felts if one is worn
Jul 01, 2008 | Zanussi TC7114W Electric Dryer
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Zanussi ZWF1440 Front Load Washer Logo
829 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
