Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Auto brush on hoover windtunnel doesn't spin anymore
On hoover windtunnel brush control wont work anymore. anyone can help?
  • 1 more comment
  • sarlulm Jan 29, 2009
    The brush won't turn on the carpet but will turn on a hard floor
  • Anonymous Apr 05, 2009
    CLEANED everything out, brush stops when it is on carpet, spins fast when not in contact with anything. Less than 1 year old, so it should not be 'worn out'
  • Anonymous Apr 24, 2009
    replaced both belts; the brush spins when on flat floor, not on carpet. The v belt appears to be too big.
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
  • 61 Answers
If this is a beltless machine as you said then the gears are probaly bad. These machine strip out the gears on a regular basis. (Design flaw!) It is almost impossible to repair this yourself, go to your local vacuum cleaner repair shop to get it done. P.S It will be VERY expensive. Expect to spend $90-$125.
Posted on Apr 15, 2009
  • 57 Answers
Do you have broken belt/s? Is your agitator brush in the right place? Is there debri on it that might keep it or the edges of it from spinning?
Posted on Jan 06, 2009
Hoover windtunnel U5453-900.belt melted put another belt on brush was spinning.Brush spins but not easily.It spins then stops therefore burns the belt.How can i get the brush to spin around better
Kristie,
I would suggest taking the brush bearings at each end off and clean any lint or hair that might be in the ends of the brush. If you have regular ball bearings on your brush, you might need to replace the brush roller if the bearings themselves are tight. Hope this helps!
Apr 05, 2015 | Hoover Vacuums
Hoover UH70935 windtunnel agitator spins like crazy with plate off after cleaning but will not with plate replaced.... what is going on?
If the brush roller was removed, it may have been reinstalled incorrectly, causing it to bind on the bottom plate.
Aug 08, 2014 | Hoover WindTunnel 3 Pro Pet Bagless...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Mar 21, 2009 | Vacuums
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
3,444 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
