Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Water leaks from two locations on my Badger 5, 1/2 hp disposal
Approximately six inches from the bottom of my Badger 5, 1/2 horsepower disposal in my kitchen sink water has begun leaking out of two small holes that are 180 degrees apart. Are these 2 holes due to corrosion and use? It just seems strange that there would be two holes, the same size, exactly opposite from one another, 6 inches up from the bottom, that started leaking at the same time.
Is it time to replace my disposal?
Thank you!
Rick Kettell
  • Anonymous Jan 14, 2009
    i have same probl
  • jetguy Mar 20, 2009
    I have a similar problem; leak from the area where the bottom cannister appears to join the top unit. It sounds like there are no gaskets or seals involved.
    Scholar:
  • 127 Answers
These holes are probably due to wear, as they are at about the level of the cutter. In general, residential disposals are not repairable and once they begin to leak, they must be replaced. The Badger series is Insinkerator's budget line and probably has about a 5 year lifespan with normal use.
Posted on Dec 23, 2008
My badger 5 disposal is leaking from the side whats wrong
Check where leak is coming from.
1) Run water until leak starts. Use dry paper towel near top of disposal to see if sink strainer is leaking.
2) Move paper towel down and check where dishwasher connects to disposal.
3) Move paper towel down to tubular drain tailpiece.
4) Water should run down side of disposal if sink strainer, dishwasher connection or tailpiece are leaking. You can fix these problems using tips below.
5) If disposal is rusted out, then water will leak out of bottom or side of disposal body.
There are no repairs or repair parts for disposals.
I wrote EZ installation tips for garbage disposal from when I worked apartment maintenance that will save time and sometimes money:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 19, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a badger 5 plus and it started to leak water from the bottom of it. Please let me know if there's a seal I can buy and replace .
A new seal costs more then a new disposal..
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
Sep 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: leaking out the bottom...
Here is a tip that I wrote about how and where a garbage disposal will leak andwhat can be done to fix it.
heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water has begin to spray/leak when using the
heatman101
g
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I just noticed that my insinkerator Badger 5-75
heatman101
May 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 is leaking from the bottom. It runs, but water runs out of all spots on the bottom; including the ara where the conduit runs into the unit - please help!
My bet is that the garbage disposal in not what is leaking... the connection to the bottom of the sink is leaking and running down the sides of the disposer...
Look higher and you will find your leak..
How is the best way to use a Garbage Disposal
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
heatman101
May 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water leaking out of bottom of unit, near reset
heatman101
p
Nov 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water is coming out the bottom of my Badger 1 disposal. Solution???
Check the fittings, the hoses could be loose... If the leak isn't coming from there then you have a seal leaking or a rust through that is causing water to leak and would need to replace the disposal.
Oct 06, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,976 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
