Question about Dell Inspiron E1505 Notebook
Error message after installing memory ram upgrade.....
Ok, I bought some ram memory (pny 2gb 2x1 gb of ddr2 pc2-5300 533mhz memory) I already had the stock ram inside which was the 512mb. installed the 2 sticks of ram booted up and after a couple of minutes I get a error message on a blue screen !!? tryed reinstalling the ram a couple of times and nothing. I put the oringinal stick back in and im able to type this email for help. what should I do ? is this ram even compatible with my system ?
  • farmgrenade Dec 21, 2008
    Ok I just installed one stick of ram and seem to be cruising so far in the process so thanks guys once again P.S. one of my internet browsers just crashed which was my mozilla firefox web browser, but i guess I will have to go back to windows internet explorer
  • 55 Answers
Your memory appears compatible with your model of laptop. It is possible that you have a bad stick of memory. Try installing the sticks 1 at a time and boot up with each stick separately and see what happens. If 1 of the sticks allows you to boot but the other does not then I would contact PNY for a replacement stick. Just to double check here you are installing 2 gigs total not 2 2gig sticks for a total of 4 gigs. Max memory for Dell Inspiron laptops is 2 Gigs.
Posted on Dec 20, 2008
  • 81 Answers
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
Upgrade problems
Your system comes stock with one stick of DDR2 (512 MB), which means that it is _ not_ dual channel DDR2 memory as dual channel DDR2 must be installed in matched pairs. Try to exchange the new memory for 2G of some single channel DDR2.
Jan 28, 2009 | eMachines W3507 PC Desktop
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Dell Inspiron E1505 Notebook Logo
429 people viewed this question
Clive
Clive
Alun Cox
