Question about Sony SDM-HS53 (Black) (Gray) 15" LCD Monitor
Sony SDM-HS53 Monitor Goes Blank
The monitor turns on and shows a screen for a few seconds. The green power on LED reamins on.
  • Richard lambert Apr 06, 2007
    I orderer a new cable on E-Bay so have not tried solution. The person who gave me the monitor tried it with a good cable and it did not work. I was also told that if the display resolution did not match the the same thing would happen. I have also bought a monitor with a broken screen which may have good electronics.
I used to have the same problem until I discovered that the cables in the back of the monitor weren't securely connected. I have a very similar model monitor to the one being displayed here
Posted on Apr 03, 2007
Power
Either a loose/bad power cable or the backlight is failing.
Jan 30, 2018 | Sony SDM-HS95 19" LCD Monitor
Power
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
Sony SDM-HS53/HT 15 in. Flat Panel LCD Monitor. I have using the monitor for a long time. I just bought a computer (not a laptop). The monitor is not being recognized. What's the problem? The monitor is...
get the mane and model of the monitor go to the manufacturers web site and down load and install the latest driver for the monitor that matches your operating system on your new computer .
I hope this helps Andrew A
Apr 12, 2011 | Sony SDM-HS53/HT 15" Flat Panel LCD...
SDMHS53/H-Gray upc code
If you are looking for any UPC Code for a SDMHS53/H, for an example, I found the following posted online:
Brand: SONY
Model: SDM-HS53/HT
UPC: UPC0027242625280
Please let me know if I can further assist you.
Regards,
KYTechnology
Mar 02, 2011 | Sony SDM-HS53/HT 15" Flat Panel LCD...
Screen going blank on system boot and on switch off/on
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a fraction of seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 08, 2010 | Sony SDM-HS75 17" LCD Monitor
I have a sony sdm-hs75, power up then then the screen goes blank, power button is still green, with a bright light I can see the backgroud, caps look good, no cold solder joints. no hot spots on the borad.
try to perform selftest on the monitor..
  1. turn off the monitor
  2. unplug the video cable from the computer
  3. turn on the monitor wihtout the video cable connected to a computer
  4. you should see the information box on the screen (it indicates that there is no problem when you see the information box). Else, monitor backlight is dead.
Mar 18, 2010 | Sony SDM-HS75 17" LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Monitor powers briefly then goes blank
Sounds like a Control board issue or a Power board issue... Might be blown Capacitors, in which case there is not enough power being supplied. Check to see if there are cheap parts on Ebay as replacements. If you don't want to go through the trouble sell the LCD itself for $150-250.
Dec 18, 2008 | Sony SDM S81 18 in. Flat Panel LCD Monitor
Sony SDM-HS75 tft lcd monitor
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
Sony SDM-HS53 (Black) (Gray) 15" LCD Monitor Logo
243 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
