Question about KEIO PS2 Optical Scroll Mouse
My head i hit my head now i think im retarded
  • 55 Answers
You may want to get a cat scan or MRI for that. Check with WEBMD.com I believe they may be able to be of better assistance.
Posted on Dec 20, 2008
Why are you so retarded
Im not retarded im a girl n obvious if a car dont move forward or backwards kinda seems like it has something to do with transmission. You know the the mechanism by which power is transmitted from an engine to the wheels of a motor vehicle.
Mar 10, 2015 | Cars & Trucks
Im getting codes P0011 and P0014 on my 2011 kia serento. Is mean my camshaft sensor is bad? if so where is it?
These codes have to do with the CVVT(continuously variable valve timing)solenoid. I guess it is a 2.4 liter engine, the solenoid is located right above the power steering pump at the #1 cylinder in the cylinder head. If it is the 3.5 liter it is located on top of each cylinder and is accessed after the intake plenum is removed. Either way, the solenoid controls valve timing of the exhaust cam via the solenoid which uses oil pressure to advance or retard the timing. The first step is to verify proper weight of oil and level. If the engine is over due for service, get it done. If the oil is not an issue, then the solenoid is becoming sluggish in advancing or retarding the camshaft and should be replaced.
Mar 01, 2015 | 2011 Kia Sorento
How do i change a piston head in a 2010 hyundi sonata
You could have a timing belt that has slipped. This would mean the pistons are hitting the valves. This is not an easy job. You have to drain the coolant, take off the exhaust and intake manifold, take off the head to the cylinders on the engine block. Check for damage to the pistons, replace everything and change the oil.
Aug 01, 2014 | Masterflex Series Q Valveless Piston Pump...
Clunking noise when I hit bumps fuel low it stalls oil in anti-freeze
You probably have a cracked cylinder head. Has the car overheated or been run really low on
oil?
Could also be a blown head gasket. But the clunking sound when you hit bumps makes me
think the one of the cylinder heads is cracked.
But oil in the antifreeze is a sign of:
1) Cracked cylinder head.
2) Cracked engine block
3) Blown head gasket.
I think its a cylinder head because its a lot easier to crack a cylinder head than an engine
block.
Aug 07, 2011 | 1991 Cadillac DeVille
Kenwood
run a constant hot (from a fused BATTERY lead) most folks will usually use a 0 or 2 gauge wire for "main" power and ground keep the ground as short as possible (it will hit much harder) and a normal I think 16 or 18 gauge for the "trigger" wire from the head (radio) hope this helps :)
May 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
Speakers tend to go in and out
absolutely.. grounds and scrubbed wires t o ground (shorts) intermittent will cause all you are experiencing
Nov 24, 2008 | 1999 Oldsmobile Alero
Spark Knock
so not a new kid on the block.  I but it on digital tech all is normal check timing it was dead on   I have retarded it 2(dig) still there new plugs no help. I got back to CA were the fuel is better and am running 101 octain fuel a bit better but still there. I am thinking I have carbin biuld up on my pistons and heads.  What Do you THINK.  Has any one other than me had this happen to thenmy 12 used to ping all the time in the summer. tried retarding the timing but it got weaker, and retarding the static timing actually can compound your issue since you are actually removing fuel as well. I went nuts trying to track it down but eventually worked its way out as i tuned my mods. I would try running a few tank fulls of Chevron Techron through it along with top quality, high octane gas from a station thats busy. even better if its a multi-pump type rather than single for all octane types. only time i experience ping now is if i'm sitting in traffic for a ridiculous amount of time and i get on it coming off a light. i just get some air on the motor before romping on it again in that situation. never even think about it these days. try the Techron and see if that helps clean things up.,,,
Nov 10, 2008 | 2007 Buell XB12X Ulysses
Cant download demos
You are such a rude person i wouldnt give you any advice if i got paid 4 it, i recently put a problem on this site as a first time user and your solution was completely uncalled for. freakin parents??? retarded 5 yr old druling??? you are very lucky im not taking this any futher as i imagine slander would be an appropriate word for the response i got off you. if you dont have any thing remotley interesting to say DONT bother adding soulutions for peoples problems!!!!!
what a dearly sad life you must live.
i feel sorry 4 you.
Oct 20, 2007 | Sony Playstation 3 (PS3) Console
KEIO PS2 Optical Scroll Mouse Logo
119 people viewed this question
Top KEIO Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a KEIO Computer and Internet Expert? Answer questions, earn points and help others
