Question about Panasonic SA-XR25 Receiver
Loses audio in tv mode
When using the receiver in TV mode I occaisionaly lose the audio portion. If I turn the receiver off then on it comes back. I can go days with no problem then it will act up several times. Sometimes only minutes apart. I have reset the the receiver but it didn't fix it. Any thoughts?
I had the same problem (CD mode) but today all audio is gone. I opened it up and found no visual problems. There are 3 main boards inside, one where all audio inputs go to. I think that board is bad. Not much help I know. Good luck finding the answer. I'm doing a search on know problems now, If I find anything, I'll post back.
Posted on Jun 28, 2007
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at askOnkyo@us.onkyo.com, Thanks,JT
May 04, 2015 | Onkyo Audio Players & Recorders
When in video mode only plays through one front speaker
Hi Richard please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Apr 01, 2015 | Onkyo HT-R560 Receiver
TX-SR333 Bluetooth worked the 1st time now won't pair up.
Hi, Please try the following reset and then try to pair again.
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "CBL/SAT" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
Feb 27, 2015 | Onkyo TX-SR333 5.1-Channel Home Theater...
HDMI flashing screen on Onkyo TX-SR674 receiver need advice on how to solve this problem
Hi Zach, you can try the following reset as this might be a glitch in the processor.
Feb 21, 2015 | Onkyo TX-SR674 Receiver
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Jul 13, 2009 | Yamaha RX-V861 Receiver
Yamaha Receiver loses audio when changing DTV stations
I believe changing stations is triggering the protection on receiver. When you go to another input and back you give time for the protection circuitry to release speakers again. Try muting your receiver before changing channels. Good luck!
Nov 21, 2008 | Yamaha RX-V463 Receiver
The problem with my NEC 68T90 TV is that the screen resolution is not correct. At 4:3 ratio, I can't see the sides of any video or TV program that I'm watching. Is there a problem with the hardware?
Try the aspect button on your remote, or if you have this hooked up to a cable or satellite converter, there are screen resolution preferences, you can change the screen resolution here, go the the menu portion and look for video/audio field
May 07, 2008 | Televison & Video
Video Issue with SA-HE200
You might want to re-wire your system so that the SA-HE200 only handles audio for the various components. Run video lines directly to the TV/Monitor. Always use the best (most advanced) matching cable type between the two.
I always setup my systems like this anyway. You end up using less and shorter cable runs and often get to use a video cable type the audio receiver doesn't support.
Mar 22, 2008 | Panasonic SA-HE200 Receiver
No sound coming from reciever from tv
Make sure connections are going-audio out from tv to d-tv/cbl in on back of reciever. Then turn on tv and turn reciever input to d-tv/cbl and make sure the input mode is on auto. Hope this helps you.
Jan 24, 2007 | Yamaha HTR-5440 Receiver
Panasonic SA-XR25 Receiver Logo
154 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
