Question about Crown CM-311 AE Microphone
Ipod multimedia docking station plus karaoke
Having trouble getting the microphone to work,is there like a troubleshooting site that i can go to or is there some better instructions
No.
Posted on Dec 22, 2008
Water spilled on ipod still works on docking station
Your home and/or ON/OFF button circuits may be oxidated from the water. You cannot fix this yourself. Find an authorized Apple service center nearby
Jul 09, 2012 | Apple iPod Photo 60 GB White M9830LL/A 4th...
When we play our iPod on the Bose system, the sound isn't in stereo. It kinda sounds like a karaoke machine. It used to work just fine. What could have happened? What can I do to fix it?
Maggie, you haven't stated which Bose system you have but the generally if the pop vocals are virtually inaudible and and it sound hollow then your ipod connector is damaged and one of the audio pins is not making contact. I have repaired hundreds of systems and you can spot it straight away. Assuming it is a Sounddock then the most inexpensive best is to 'buy and try' a docking connector from www.invebo.com. You can do it yourself click here to see the guide video. (Buy and try means that you are guaranteed a refund if it doesn't fix your problem)
Mar 05, 2012 | Bose SoundDock digital music system...
No audio from docking station PA3314U-1PRP. Laptop itself (Tecra M5) outputs audio normally. All other outputs from the docking station work normally. How do I get audio to work through the docking...
you should try plugging from the output port of the laptop to the input port of the docking station, remember the source is coming from your laptop going to the docking station.
Now for the microphone once you have the settings right the line in jack should work properly.
Hope this helps!
Jul 22, 2011 | Toshiba Advanced Port Replicator III...
IPOD works fine;but it,s unresponsive in the Bose docking station/speaker system. Remote has fresh battery. Only used a couple times. Thoughts?
I had the same problem and once I reset the ipod it started working again. Don't know if this will work for you but it worked for me, Hope it helps.
Aug 28, 2010 | Bose SoundDock iPod Digital Music system...
Cannot get a radio to set - need directions as I don't have mine
Go to the manufacturer's site and download the instruction set. Hope this helps .
Aug 05, 2009 | Audiovox Jensen Universal iPod Docking...
Isound spa station won't charge my ipod nano
i THINK its because it was made before the ipod nano 4th gen and ipod touch so it does no support the system.
Dec 25, 2008 | Homedics iSoundSpa Clock Radio with...
Denon receiver (DRA 397) will not speak to iPod dock
IF YOUR NOT USING A DENON IPOD DOCKING STATION IT WILL NOT FUNCTION CORRECTLY.
YOU CAN CONNCET OTHER TYPES OF IPOD DOCKING STATIONS BUT YOU WILL NOT HAVE CONTROL THROUGH THE DENON AND ONLY CONNECT THE AUDIO FOR THAT DOCKING STATION TO THE DENON AS ANOTHER SOURCE INPUT
Oct 13, 2008 | Denon DRA-397
IPod Nano 3rd Generation
Hello Nada19,
The dock connector is the connector at the bottom of the iPod which the USB cable you use to connect the iPod to your computer plugs into. This is also the connector that is used to connect your iPod to a "dock" such as this one. An iPod dock, like this one is a device that you drop your iPod into for charging. It typically also has a connection for external speakers that can be used with the dock.
Not all models of iPod have a dock connector. And the actual layout of the dock connector varies from model to model. It sounds like you will need to use an iPod model that does have a dock connector to interface with the karaoke machine. You may also need an interface cable. Consult the documentation of your karaoke machine for more detailed info.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 01, 2008 | Audio Players & Recorders
162 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
