Question about Atrix (CSCI-C8001-C43) ATX Mid-Tower Case
Atrix 9006-C4 Black Midi Case 520W fitting for lcd display
I know were the power supply leads go but unsure of the connections for the fans and sensors to the mobo can you help
    Scholar:
  • 96 Answers
There will be "headers" on the motherboard for some case fans. Look for 2/3 pin connections on the board marked "sysfn" or something similar. Any other fans you will have to fit to a spare Molex power connector from the power supply ... you can buy 2 or 3 way "splitter" cables to give you more power connections from one Molex for this purpose. BTW make sure you connect the cpu fan to the "cpu fn" header !!!!! That one is rather important :-P
Posted on Dec 31, 2008
What can I do to fix dim display screen on my elna 9006
There may be an adjustment on the backlight display?
Do you have an Elna 9006 Envision manual?
Feb 16, 2015 | Elna Sewing Machines
My motorola atrix 2 wont turn on
try pressing power key + home key + volume up key at the same time, see if you can boot to recovery, then, once rebooted, select clear cache partition, then select wipe data/factory reset..
and better not use a charger not compatible to your phone.. hence it would burn those leads inside..
Dec 29, 2012 | Motorola Mobility Atrix 2 - 8gb - Black...
Citroen C4 automatic. After car has been driving then stops, the fan keeps going until battery runs dead. The AA fitted brand new battery but problem persists. Any ideas?
Most "CCC" Or computer comand controlled vehicles supply power to the electircal components automaticaly via a relay, there will be one power source with the ignition off,& a second power sourse when the ignition is turned on,In this case the temp sensor will supply a ground to the cooling fan circuit when the engine temp reaches a specified temperature and the fan comes on. In my opinion you most likely have a relay that has malfunctioned(gotten too hot & fused internaly) find your engine cooling fan relay(s) & remove them.If the fan stops you may have found your problem.to check the power supplied to the relay you will need a simple test light, connect the clip to a good ground & probe the relay socket with the tip of the lights probe. where there is power the test light will light up. Ignition off-1 power source,Ignition on-2 power sources/ to check for the ground supplied by the temp sensor connect the test lights clip to a battary+ source & probe the relay socket again if there is a ground supplied the test light will light up, there may be more than one temp sensor in the cooling system.you should be able to aquir a wiring diagram online if you do not have a book.one of the sensors sends the temp signal to the gauge in the dash, & the other is the ground supply for thr fan relay. I hope I have been of some help.
Dec 15, 2012 | Cars & Trucks
Elna 9006 lcd backlight is off
Try this link for an affordable solution to repairing your Elna Envision 9006 Display Back Light.
Elna Envision 9006 LCD Backlight Replacement Kit
Oct 14, 2012 | Elna 8007
Hi guys, i have a power supply HP-Compaq-226519-001 bought from ebay. the seller said it is a working pull-out and i was able to locate the AC input terminals/pins as well as the DC output terminals but...
Go to this link. Click HERE. Unplug from the motherboard FIRST. (all other leads too) You can test by using a paper clip to short pin 14 (green) to 13,15,16, or 17. This will power on a working power supply.
Apr 08, 2011 | HP (226519-001) (226519001) 3000-Watt...
Replaced a bad power supply and now won't pass POST.
Power supplies are one of the most common failures for computers but as you have found they are also very easy to replace and a nominal cost.
I probably average 4 power supplies a week on my bench and always do as you did and suggest to clients to get a higher rated supply.
Bob.
Jul 14, 2010 | Syntax SV266A SKA KT266A Motherboard
Computer is not working
yes it is ur video card i suggest taking it to computer store
Nov 26, 2008 | E-Machines eMachines Desktop PC
Tiny CD conection cord probe suposed to fit positiveto foot 25 negative foot 26
Actually the pins go on the Slave connector (the connector in the middle of the IDE cable) while the CD/DVD is connector to the Master connector which is on the end.
Apr 02, 2007 | Atrix Black Gamer Case w/ Maximum Filtered...
Computers & Internet Logo
487 people viewed this question
Top Atrix Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Atrix Computer and Internet Expert? Answer questions, earn points and help others
