Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
  • mobushwacker Dec 21, 2008
    thank you i will call them
    still need a fix thank you if you can help
  • RCA Master
  • 5,138 Answers
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Posted on Dec 21, 2008
  • ladywinn
    ladywinn Dec 21, 2008
    hori output is a NTE2324 transistor/ Go to type in your make or chassis number look to see if they have Flyback transfomer FBT.
What does a power supply failure on a tv?
??? what does a power supply failure on a tv look like ???
none of the buttons light up , nothing lights up no bars or stripes on screen , nothing !! cord is plugged into a power outlet and is on , but nothing no lights no sound (sometimes a high pitch squeal is heard )
Aug 03, 2016 | Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
Aug 23, 2013 - Uploaded by
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a peavy classic 100 2x12 1975 has a high pitch squeal coming out of amp when powered on
If this happens only when the guitar is plugged in, most likely there are two possibilities. The first, you have some issues with the electronics in the guitar OR are using an acoustic guitar witch has an extremely sensitive pickup that provides nothing but feedback. If this is happening with the guitar unplugged, there is a mountain of possibilities.
Sep 01, 2014 | Music
Canon imageclass MF8180c squeals
Try replacing the Drum Unit, this is a problem I have encountered many times as a service technician. most recently I had one that was at 89% remaining and every time the unit begins the print process it makes a high pitched squeal.
May 01, 2012 | Canon imageCLASS MF8180C All-In-One Laser...
My Microwave continues to run unless door is open. I do not think it is heating though when I shut the door. When I close the door and push buttons nothing happens. I get a high pitched sound when I...
The high pitch sound to me may be coming from the speaker on the main circuit board. Try to unplug for a few minutes, reset clock time and then try again. If same issue, may need new PC board. When you say Microwave continues to run are you meaning the Turntable is turning and the fan running?? Or is it just timing down. Almost never does it actually keep heating. On GE units I mostly find bad door switches will cause a back feed and make the tray turn and the cooling fan for the mag to run. To see if that is the problem You have to look at the door switches behind the front panel on the left side and see if any of them have any browned connections on the terminals where they push ontl the back of the switch. That will cause the fan and turntable toi run, but wouldnt cause a high pitch squeal. These companies use switches wtih small 3/16 terminals that dont give a good enough grab on the switch, they get loose and hot and make the switch go bad. I replace that switch with a switch with 1/4 inch terminals and runa short section of Hi temp wite to it and it wont go bad again. Just cheaply made!! Also I guess the squeal could come from the turntable motor area. So By fixing the switch problem it could fix your squeal. With nothing else running you may be able to hear motor and coupling noise you couldnt hear before.
Aug 17, 2017 | GE XL1800 1100 Watts Microwave Oven
LCD tv won't power on...
The power board is dead,replaced the board.Well get the power back.Tries, for the part.
Jan 26, 2010 | Televison & Video
I have a Toshiba 27AF42 and I get a high pitched squeal after the TV has been on for a few minutes. Any ideas how to fix this? Once I turn the TV and back on again the squeal goes away.
yes. its the horizontal linearity coil resonating. take off back. and while unit is on, take a plastic straw and push on coils in the high voltage area. you will find one that squeals when pushed on, or will stop squealing when pushed on. solder that coil and area. that will fix 80 percent of the time. if you push on it and the squeal tone changes, solder it and silicone it done. fixed.
Nov 14, 2009 | Toshiba 27AF42 27" TV
High pitch squeal
sounds like the tensioner for the belts is worn
Apr 08, 2009 | 1996 Geo Tracker 2 Door
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
176 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
