Question about Yamaha HTR-5540 Receiver
Need instructions on hooking up speakers to HTR-5540 reciever
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Speaker hookup procedure is described in instruction manual.
    If you need any specific info about speaker hookup, let me know.
    Brigadier General:
  • 8,546 Answers
You can find the manual on Just register and download it.
Posted on Mar 13, 2010
How to program a remote for a yamaha HTR-5540 receiver if you dont have the original remote.?
follow the instructions in the manual of the remote that you bought,also,you need a remote that can work audio,
Apr 11, 2017 | Yamaha Audio Players & Recorders
When watching cable tv we are not getting any sound from the speakers. We do get sound from all the speakers when watching a dvd or listen to the stereo. I have a Yamaha HTR 5660 receiver. All the cables...
Your best bet is to hook all your video components directly to TV, using your TV's menu to choose what you want to watch, and then hooking reciever to TV via digital optical out from TV to digital optical in on reciever. From what I read, your reciever has 6 digital optical inputs. Anyway, try running, at least, your cable box to TV, best by HDMI, the run digital optical out to reciever. Make sure you go throught he recievers menu to make sure you have he right channel selected for audio.
Jun 25, 2011 | Yamaha HTR-5660 Receiver
Need instruction for HTR-5540 product how to setup
Hi,you can download the user's instruction from the below link.
Hope it helped.
Have a nice day.
Feb 24, 2011 | Audio Players & Recorders
After plugging in my speakers and identifying the input and hooking it all up sound is still not coming out of the speakers. I continuously check how I set it up but its still not working.
Modern equipment has speaker select switches usually marked a and b , you could try the headphone o/p to see if they work.
First check all your connections to make sure all is ok.
Make sure you have an input selected that you have tested to ensure it is working then use that input to try the phones and then if that works try the speakers.
Always try out non working equipment at LOW level this will protect your equipment AND your hearing.
Hope this helps
Thanks for using FixYa
Aug 19, 2010 | Yamaha HTR-5540 Receiver
Can I connect my ipod to my yamaha htr 5540 via some kind of cable?
Yes - just go to electronics store and buy a 3.5 to 2 RCA lead and plug the 3.5 plug into your IPOD and the RCA plugs into the Aux sockets on your Yamaha. Job done
Mar 19, 2010 | Yamaha HTR-5540 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
4 ohm speakers on Yamaha HTR 5540
Model number of the Lux? The only unknown to me regarding the answer is if the Lux speakers are designed for non-Lux attachment. If there are molded connectors on their leads I would be cautious as that is usually the manufacturer's subltlke clue that you really don't want toi mix them with other makers. If they're bare wire I think you're ok.
The impedance selector on the receiver supports minimum 4-ohm front and 6-ohm center and rear, so you'd be marginal on those last two, but barring excessive high volumes I'd think it would work. The powered sub is supported and its impedance spec is irrelevant.
Just curious, is this an upgrade in electronics? From what?
Feb 23, 2010 | Yamaha HTR-5540 Receiver
Problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Jul 25, 2009 | Yamaha HTR-6030 Receiver
Factory settings
I only found this on the manual
if the power is cut for more
than one week, the parameter value you edited will
return to the factory setting."
May 13, 2009 | Yamaha HTR-5540 Receiver
Yamaha HTR-5540 Receiver Logo
130 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
