Question about Samsung YP-U2X Digital Media Player
Recharging My player just quit on me even though I hadn't used it hardly at all since I had it last plugged into my USB port. I put it in the USB port and left it there overnight. It still won't come on, I get the battery icon. My questions are: Is plugging the device into the port the ONLY action you have to take to recharge it? And second question: Does the battery run down even when you aren't using it?
  • Linda Gerhardt Apr 05, 2007
    Thanks, I got it working, but apparently I have problems with files that are no longer where they used to be. I wish they would just let you transfer a file and forget about the path and all that stuff... so I formatted the drive and started over. Thanks again.
    Scholar:
  • 113 Answers
- Yes, in order to charge this device, all you need to do is to plug it in - The battery doesn't run down no matter how long your are not using it. I had one and i didn't use it for over 6 months and it was still working. - Are you able to see it as removable drive under my computer? - Try connecting it to a different USB port or a different computer - If it is viewable under my computer, try to see if you are able to transfer files Please revert back with further observations
Posted on Apr 03, 2007
Wriggly USB port
Typically this is the beginning of the end for your player. However there are some things to try. You can take a pair of pliers and bend ever so slightly as USB cable so that it places pressure on the bottom part of the connection on your MP3 player. I would try this with a cable you don't care for. I wouldn't suggest doing anything with the player. So many users bring my their blackberries that have the same issue. Most users do not come back to see me for quite a while or until the device is dead. These devices require tight connections, the only other option is pressure and that is what bending the plug does. Lastly, notice the two little notches that come from the wider side of the metal part of the USB connection. Are they protruding up even slightly? That may tell you something is wrong with your USB cables.
May 09, 2014 | Coby MP620 MP3 Player
Simple Tech 250 GB external hard drive won't work
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 23, 2009 | SimpleTech Signature Mini 250GB External...
Cruzer Micro USB Flash Drive ReadyBoost not working
PLEASE TAKE NOTE OF ITEM 3
Sep 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Comstar USB Drive disconnect and reconnects Plugged into usb port on Xp service pack 2
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
Sep 08, 2009 | IBM Computers & Internet
External hard drive model #47560 wont display on "My Computer" im runing vista ??
USB hard drives should be treated with extreme care. this is a real hard drive and knocks and bumps can quite literally kill them.
Sep 07, 2009 | Verbatim VER95327 USB Hard Drive
Pc doesnt detect/read portable HDD, but a USB connection appears on the task bar
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
Sep 05, 2009 | Toshiba 120GB USB 2.0 Portable External...
Computer wont recognize my e book...it was working fine last nigh
Aug 30, 2009 | Western Digital My Book Home 320GB...
Usb ports not working
Aug 28, 2009 | HP Pavilion dv6-1030us Notebook
T20 low battery and no recharging
this is problem with your hardware.......
Jun 20, 2009 | iRiver T20 MP3 Player
No recognition
This happens to my ditty quite often. When it does happen I plug it into the USB port and press the reset button on the Ditty until the computer recognizes it.
Nov 24, 2007 | Dell DJ Ditty MP3 Player
Samsung YP-U2X Digital Media Player Logo
76 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
