Question about Yamaha RX-V1500 Receiver
RXV1500 drop outs
Hello i have a RXV1500 and it is dropping out for about 1 sec every now and then during low output levels while using DVD/DSP . has anone come across this before? regards
Hammo ,
I know its been almost a year , but i had the same problem and after a few days i found out it was my optical cable causing the issue. The optical cable was brand new and all of a sudden it just started dropping sound for 1 sec every now and then. i changed the optic cable and all has been good since
Posted on Sep 06, 2008
TV audio output vastly different for satellite feed versus DVD feed. Why?
It is possible there are separate sound level functions for the DVD player, the tv and the satellite box, try the different remotes for each by unlocking the volume control on the satellite remote until you get them close or use the device specific remote volume controls. I would also try and use HDMI if available for the DVD instead of composite. If the volume controls are different it will show on the tv, might also go through all audio settings for each device. Some devices are pre-amped or send out strong sound signals while others are line level outputs designed to be amped by the output device, in this case your tv I believe. The HDMI vs stereo audio that goes with composite may be the cause or it could be in the settings of the device. Worst case is to remember to drop volume before you switch back so you don't ruin speakers.
Jan 25, 2015 | Televison & Video
Riso HC5500 S01-204 error
  • Code: 001 S96
  • Description:Power supply remote signal not connected The control signal cable for the ON/OFF control of the 24/38-VDC output is disconnected. The signal wire grounded inside the power supply unit has been pulled up by the IP PCB to detect the level.
  • Code: 003 S97
  • Description:38-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 38-VDC resistance inside the power supply unit. The detection level is approximately 18 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
  • Code: 004 S97
  • Description:24-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 24-VDC resistance inside the power supply unit. The detection level is approximately 11 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
  • Code: 006 S97
  • Description:3.3-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 3.3-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
  • Code: 007 S97
  • Description:1.8-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 1.8-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
  • Code: 008 S96
  • Description:Control panel not connected The absence of the control panel unit to be connected to the MC PCB is detected. Since this configuration lacks this panel, this error indication will not be issued under normal operating circumstances.
  • Code: 009 S96
  • Description:Print counter not connected The absence of a print counter is detected.
  • Code: 011 S96
  • Description:CIS PCB not connected The connection of the CIS PCB cannot be confirmed.
HP Printer Support Phone Number 1 850 610 1013 HP Support Assistant
Dec 11, 2013 | Riso Office Equipment & Supplies
Recording levels are low
There's no record level adjustment on the Masterlink. Increase the output level of your mixer, or add a variable level preamplifier between the mixer and the Masterlink.
Or, use the level adjustment on the Masterlink once the recording has been done, and before you write it to CD, either with level control or DSP normalisation
May 23, 2013 | Alesis MasterLink ML-9600
It's sound very low
Double check the condition of the cables, make sure nothing is shorted or broken.
Is your music source 1 volt peak to peak (or line level)? If not add a preamplifier if input is lower than that or attenuate the input if higher than that. If you have line level input, make sure the input is turned up to an optimal level for output with headphones. See that you are getting correct response on the input LED level indicators. If all are lit up, you need to attenuate the signal before it plugs into the amp.
Check your system presets, check to make sure DSP is "OFF"" at least for now. And then check to see if you have "Briged" "Stereo" or "Mono" selected. If you plugged one speaker in and plugged it into the jacks for the bridged configuration, you are fine, if you plugged into one or the other, or used two speakers, You would want "Stereo" at least for testing. "X-over" would only be needed for Bi-amping a mono imput. And scroll through the other presets to see that limiters are off, and that system is not muted.
Then turn up the amplifier volume.
If you wired 3 speakers to it, that might be why.
Other possibilities are impedance mismatch between output and speakers,
This url has the Manual and specifications you can download
http://www.crownaudio.com/usa/xti-series.html
If the unit shows any signs of having been dropped, there may be broken solder tracks internally. such an event as being dropped could cause some of the issues you are encountering.
Oct 30, 2012 | Crown XTI-1000 Power Amplifier
Yamaha DSP-A1 sound drops at startup
In the manual it says switch off leave for 30 seconds and switch back on .
Aug 07, 2009 | Yamaha DSP-A1 Receiver
Plug in reciever and it shuts down nothing hooked up into it yet
Have seen regulated voltages drop a volt on two causing this problem . the regulator with the low output needs changing. Voltages can be checked pretty easy at the one large connector coming from the regulator sectionto the dsp board.
Jul 16, 2009 | Yamaha HTR-5860 Receiver
Please advice me as soon as uyou can ..thx
Start troubleshooting the problem by checking the physical layer (Plugs, Jacks, Cables). Replace them with known working equipment.
Once you have traced the line from your Cisco to each other end (through to ISP, and to network switch), then reset your error counters, by restarting the cisco.
Check the ethernet interfaces on the network switch and the Cisco. Make sure they are both set to Autonegotiate or both set to the same settings like 100mbs Full-duplex. If they are not communicating the same way lots of errors will be generated.
Nov 09, 2008 | Computers & Internet
Volume level dropping unexpectadly
The A1 has an internal self diagnostic program which you can go through to find the fault. You can access the diagnostic program by simultaneously pushing some buttons on the front panel. The Yamaha service manual for the A1 tells how to do it and what the diagnostic codes mean. You can get a copy of the service manual on the web from several suppliers for a small fee.
Nov 18, 2007 | Yamaha DSP-A1 Receiver
Also problem with Denon AVR-2802
If DIGITAL sign on the display blink, it mean the DSP board is defective. probably the DSP itself
Jul 22, 2007 | Denon AVR-2802
Yamaha RX-V1500 Receiver Logo
95 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
