Question about Akai PDP42Z5TA 42 in. Plasma Television
AKAI Menu screen wont stop flashing over tv signal
I have a 42 in Akai PDP42Z5TA. Its worked great for 1.5 years.
Now after being turned on, the menu screen flashes for 1/2 second approximately every 1 second continuously. The control buttons on the tv and the remote are all frozen. When the menu button is pressed and held on the TV, the menu screen is visable and stops flashing, but no other buttons work.
Is there a reset somewhere on the TV? Or is there anything anyone can recommend. I cant get service on the TV because it is not a Samsung.
    Top Expert:
  • Akai Master
  • 75,178 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on May 11, 2017
retrohack
  • 27 Answers
SOURCE: AKAI LCT2721AD remote signal not working
This model is notorious for ring cracks in the solder joints on the IR sensor inside the television unit itself. The problem seems to come from pressure being applied to the board during installation. I have repaired three this month! It is a simple fix (just have to reheat the solder joints) if you know how to solder.
If not, the unit will more than likely have to be serviced by a repair tech.
Hope this helps you out.....
Posted on Oct 21, 2007
Danmart
  • 291 Answers
SOURCE: Akai TV Stuck in Video Menu Page
Unplug TV for about 2(two) hours, while the TV is unpluged press the on\off button on the TV every once in a while. Replug electricity and try to turn the TV without the r\c, use the on\off button only...If that does not work...u need a tech to look inside..
Posted on May 01, 2008
  • 17 Answers
SOURCE: blank screen
I repaired mine. It had the same problem. Could be power supply. If you open it then maybe I can help.
Posted on May 08, 2008
  • 4 Answers
SOURCE: akai tv wont turn on
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Posted on Jul 24, 2008
freetek
  • 5568 Answers
SOURCE: screen will not appear
You have just found out why the plasma sets are fading from the market.
Both of you may have a power supply problem. The PS in plasma TVs is more complex than in LCD sets and therefore more likely to fail.
Since Akai is so poor on product support, they may not even have parts since that set was made by Samsung who also doesn't want to hear anything about them (their site doesn't recognize the Akai model number), you may be out of luck.
In researching Akai, I find large number of folks who will not buy any Akai anythings again.
This kind of performance is unusual for a Japanese company.
Posted on Sep 02, 2008
Akai PDP42Z5TA
Back of an Akai PDP42Z5TA showing where the Power board is.
Dec 15, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Can't get anything on the screen
Unplug the power cord from the TV set and leave it unplugged for 5 minutes. Plug the power cord back into the TV and turn it on. It should work. This is not an uncommon problem for the Akai line.
Nov 02, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Screen will not appear
Jul 04, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Tv wont turn on
May 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai PDP42Z5TA settings
You have to go menu and do default .
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
No picture or sound
what do you have connected? you can try withe basics. if you can try a rg-6 cable into the f connector. then try a dvd on video 1 and change the input to input 1 and see. if nothing else try a hard reboot
thats unpluging the tv for about 2 min. then reconnect.
Apr 08, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Pdp42z5ta AKAI Problem
Write a workorder statinf the television cannot be repaired - return it to the customer then have the customer call 800-726-4005 - and request an exchange.
Mar 12, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Jan 06, 2008 | Televison & Video
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai PDP42Z5TA 42 in. Plasma Television Logo
54 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
