Oil in the Tub getting on clthes
Notice oil spots on our clothes after they were washed. Looked in the tub and found a small spot of oil in the bottom of the tub
    Problem Solver:
  • 12 Answers
The oil will be coming from the bearings it usually comes onto clothes as brown rusty colour spots if so change bearings
Posted on Dec 21, 2008
Leaves spots on my clothes
Kathy, you may have the beginnings of a tub bearing failure. What usually happens is the water seal fails on the tub drum shaft. This lets water into the bearing cavity and usually some grease migrates out into the drum. What eventually happens is the wash water eventually washes the grease out of the bearings and they fail. You will notice your spin cycle getting louder and louder.
You can check for a loose tub bearing by lifting the drum gently at the top. Is there play where the drum can move vertically, independently of the outer assembly? That's my guess. You can do an internet search about tub bearing replacement if you want to get into that. Its doable, depending on your skill level. Good luck.
Been there and done that. Usually Frigidaire doesn't sell the bearings, but they are standard bearings and you can usually match up a seal.
Mar 17, 2014 | Frigidaire GLTR1670A Front Load Washer
Worth fixing dryer that is getting oil spots on clothes model mah5500bwq
This machine has no oil in the tub assembly. Over a period of time and using cold water washes body oil, dirt and undissolved detergents and fabric softener will accumulate at the water line on the inner wall of the outer tub. After the gunk builds up thick enough parts of it will break loose at times when using hot water and then get on the clothes.
Nov 03, 2012 | Maytag Washing Machines
Black oil spots on white clothes after washing
your top transmission seal is leaking oil out of the transmission,and its getting forced up thru the tub seal this condition is called "back-wash" you need to remove the tubs both inner and outer to access the seal,it takes time
Mar 21, 2010 | Hotpoint VBXR1090D Top Load Washer
Oily spots on clothes after washing, no oil or grease before washing, no hard water...where are the spots comming from. Did not happen with old washing machine
sounds like the seal at the base of the tub is allowing oil to leak from the bearing (that is allowing the tub to spin on the motor shaft.
Not much to do unless you are good with tools and can remove the tub and replace the seal. (This is sorta like the seal between the transmission and engine on a car, or around the main motor bearing)
Feb 03, 2010 | LG WM0642H
Oil coming in the bottom of my washing machine tub.
Yor drum bearings are faulty and nee replaced Quite an expesive repair
Sep 27, 2009 | Whirlpool LSN1000LW Top Load Washer
Washer is leaving dirty spots on clothes
If you use fabric softener it may be from the softener. Dilute your softener 50% before pouring it in.
Sep 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Spots on white clothes
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Clothes have oil spots on them like something is leaking into tub. possible causes? solutions?
generally oil spots are from leaking transmission fluid, and depending on age ofg machine may or may not be worth repairing
Jan 11, 2009 | Washing Machines
Washing Machines Logo
804 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
