I have a sd-p5043 pioneer projection monitor. i cannot get a pic on it or sound. it was working fine & then this?? can u help? i do not want to pay you unless you can help for sure. also is there anywhere where i can get a manual for this tv?
snakehead
  • 1074 Answers
SOURCE: help
Hi tedski have a tech look at your tv the problem is in the power supply or related circuit.good luck
Posted on Apr 26, 2007
premtech
  • 934 Answers
SOURCE: TV shuts off seconds after being turned on
This is actually a common problem with this unit and one that Pioneer is aware of... Over time the feed resistors in the convergence circuit change in value and the convergence ICs begin to fail, placing more of a load on the power supply than necessary and stressing components in the SMPS. The fix; Pioneer recommends upgrading the convergence IC's from STK392-110 to STK392-180, change all resistors in the convergence circuit that have changed in value and replace the power supply to repair the unit.
Posted on Jun 27, 2007
De Engineer
  • 247 Answers
SOURCE: need new remote not sure
You can buy a universal remote in Radio Shack, Best Buys, Circuit City, etc. or any department or appliance store. A factory replacement remote is available from the manufacturer, Pioneer.
Posted on Mar 09, 2008
  • 15 Answers
SOURCE: pioneer projection tv SD-p5oa3
only codes for pioneer tv are 0166 0679 otherwise
Posted on Feb 11, 2009
electronick
  • 505 Answers
SOURCE: my pioneer sd-p55a3 projection tv stays on for 5
probably the solder connections on the convergence board.. solder it up good and it will usually stop blowing that fuse..
what is the fuse #?
let me know if i can be of further asistance
Posted on Jun 08, 2010
Testimonial: "thanx for the info ,i will start with that, by the way the guru asked me what size the fuse is ,it was a 4a 125v but i tried a 4a 250v and it blew after 3 or 4 minutes,thanx for the prompt response Electronik "
No Picture
sound's like viedo card problem very expensive to replace I scraped a 50 in. because of the same problem hope this help's check pioneer referb auido viedo card's on internet usa their cheaper I didn't find out until after I scraped it $498.00 plus tax in canada $135.00 plus tax in usa hope this help's Rocky good luck
Dec 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
SD-P5181 Pioneer Projection Monitor Receiver Picture does not work, however audio works when plugging in my playstation II.
My pioneer projection monitor receiver sd-p5181 has something wrong with the srceen it works but it is blurry and has double the picture how do I fix it
Sep 24, 2008 | Televison & Video
Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Aug 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer rear projection model # SD-P6093-K
HELLO. IT SOUND LIKE YOU HAVE NO HIGH VOLTAGE.!! COULD BE THAT YOUR HORZANL TRANZOR IS BAD & MAY BE YOUR FLY TRANSFORMER ALSO. !!! THEY WELL NEED TO BE REPLACED.!!! "GOOD LUCK" HOPE THIS HELP'S YOU!
Aug 19, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Computers & Internet Logo
97 people viewed this question
Alun Cox
David Payne
David Payne
