Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
Laptop to tv
I connect my laptop to the tv with the wire provided (to display the computer screen on the tv.)but I got no screen on the tv. I follow the instruction also , and I tried all the videos. Thanks.
  • Anonymous Mar 25, 2014
    I use VGA cable to connect with laptop but in TV screen display message: Do not support.. Please check PC out.
    Any one have same problem with me? Please tell me how to resolve. Thanks
  • 43 Answers
The resolution setting on your pc must be in the acceptable range for the monitor to handle. Look in your tv owners guide to see the resolution range and make sure your pc is not over that range or it will not work. Good Luck
Posted on Jan 23, 2008
SOURCE:
How do I connect fire tv wired ethernet to dell laptop?
Do you mean amazon fire tv? To get picture from fire tv it can only be connected to hdmi in but laptops have hdmi out. So no go but you can access most content directly from laptop by logging to your prime account. To connect Ethernet to laptop i see no point for that. Ethernet adapter for fire tv is useful when your WiFi is slow and gas to be connected to your router not laptop. That adapter is to get Internet connection which laptop wont provide. You could set your laptop as wirelease bridge but it doesn't make sense since it won't provide faster Internet connection and since you asked question about wired Ethernet I assume that computer networking is not.your hobby.
Mar 03, 2018 | Dell Computers & Internet
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
I'm trying to connect laptop to Panasonic Viera TC-P46S30 using VGA-HDMI converter. I'm getting 'No signal. ...' box displayed on TV. How can I fix it.
on your computer, go into your vga graphics driver and hit properties, set it for dual and hit apply. close the box. then go to the graphics,options, look for dual. make sure the wire is tightly in your tv and computer. switch your tv to vga. it should be lit. then you should see your desktop on your tv screen.
Dec 11, 2011 | Televison & Video
I am able to stream netflix, however, I was told I should be able to access everything else from my PC on the TV, as well. Therefore use my TV as a laptop. How do I do that??
If your Television has netflix installed on it, you will need to connect the television to the internet and follow the on screen instructions to enter your information.
If it doesn't, you will need a device that has netflix on it that can connect to the computer (an xbox, PS3, Wii, or compatible player) that can connect to the internet. Again, connect the device, choose netflix, and follow the onscreen instructions.
I can provide more details about these on screen instructions if I know what device you are using.
As a third option, you can connect your laptop to the TV with any video or audio cord. HDMI is a favorite if your computer has an HDMI output port and your TV has an HDMI input.
Jul 21, 2011 | Computers & Internet
Hi what do I need to do to setup my Sony laptop with my newly bought 51 inch samsung tv, I have wifi at home. Any help ll be much appreciated.
You can connect the TV to the computer using the HDMI cable. All the latest Sony VAIO Notebook computers are shipped with a HDMI input port.
1. Once you have connected the TV and powered it ON verify if the TV is detected in the computer in the device manager.
2. Press the Windowds logo key+R letter key together to open the Run window.
3. Then, type the command "devmgmt.msc" without quotes to open the device manager window.
4. Now, locate the monitors option and check if two PnP monitors are listed.
5. If yes, then close the device manager window and press the Fn+F7 keys to toggle the computer screen from computer to your TV.
This will display the video to your TV.
To enable sound output through your TV, follow the steps provided below.
1. Click on start, Control Panel and then on Hardware & Sound option.
2. Click on Sound to open the sound properties window.
3. In the Sound properties window, click on the performance tab and select the HDMI device i.e; (your TV) as the default audio device.
4. Click on Apply and OK. Close teh open windows.
This will output the Audio from your TV.
Jul 13, 2011 | Computers & Internet
I have a computer cable that i connected to my laptop and zenith tv but i dont know how to get it to show on my tv, please help
Thank you for your question.
In most cases generally, Laptops need to have their display output changed to direct the display away from the screen. Again, generally you may find a picture of a "TV type" logo on your upper keys that you use with the "function/Fn" key. This will allow you to direct the display to an output source.
If you have your Users Manual peruse that firstly as there is no "one" rule that covers all situations in setup and display of computer hardware.
If this is not the case, you will need to provide more information such as the Laptop name and model number. Also, could you please supply the type of connection cable you are using.
Good luck and kind regards
Nov 22, 2010 | Computers & Internet
Dell 6000 laptop screen blanks out - bought new screen
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
  1. Follow the instructions in "Preparing to Work Inside the Computer."
  2. Remove the hinge cover.
  3. Remove the keyboard.
  4. Open the display all the way (180 degrees) so that it lies flat against your work surface.
  5. Remove the four M2.5 x 5-mm screws (two on each side) that connect the display assembly to the computer.
  6. Loosen the screw that connects the grounding wire to the system board.
  7. Use the pull-tab to disconnect the display cable from the system board.
  8. If a wireless Mini PCI card is installed, disconnect the antenna cables from the card.
  9. Lift the display assembly from the computer.
Apr 06, 2009 | Dell Inspiron 6000 Notebook
Can't view connected Dell Inspiron 9400 computer on Toshiba 37 AV52U TV
You need to change your computer display settings following your TV user manual.
Here follow the compatible display settings as on page 57-chapter 9 on manual.
Put resolution 640x480 and frequency 59,940Htz.
Here the user manual where you can find the same information on chapter 9.
See How to change display settings: screen resolution, screen
refresh
Do not forget to evaluate the solution.
Many thanks.
Mar 08, 2009 | Computers & Internet
Connecting Toshiba Lap Top to NEC LCD TV
From user manual (page 68):
Your computer comes with a built-in display panel, but you can also
connect an external display device to an available video port, as
follows:
❖ An external monitor or projector via the RGB (monitor) port
❖ A TV, VCR, or DVD recorder via the S-video (TV-out) port
Before connecting an external monitor or video projector, configure
your computer for the type of device you are connecting. To do this,
refer to the documentation for your operating system and devices
So you have to use an RGB cable or a S-video cable : your cable should be plugged into 15 pin VGA port in your PC and plug it into a correspondent port in your TV.
Try also S- video and select correponding input in your TV set (Both connection type DO NOT carry sound: use your audio connector from PC to TV audio input.)
Configure your extended screen using your manual instruction:
Once you have connected an external display device, you can
choose to use the internal display only, the external device only, or
both simultaneously. The quickest way to change the display output
settings is to use the display hot key (Fn + F5):
1 Press Fn and F5 simultaneously.
2 While holding down Fn, press F5 repeatedly until the setting
you want takes effect. Briefly pause each time you press the F5
key to allow time for the display to change.
This hot key cycles through the settings in the following order:
❖ Built-in display only
❖ Built-in display and external monitor simultaneously
❖ External monitor only
❖ Built-in display and TV
❖ TV only
Jan 12, 2009 | Toshiba Satellite A135-S4527 Notebook
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
132 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
