Nikon COOLPRINT Thermal Printer
Problem for Nikon COOLPRINT Thermal Printer
Is there any clever way to be cost-effective when printing (I seem to have more paper than ever and ....
By kioner - usenet poster
Is there any clever way to be cost-effective when printing (I seem to have more paper than ever and know that each sheet is a minor expense that can mount up to a major cost)?
Best Solution
posted on May 15, 2006
Very Helpful)
bmwrider
Rank: Wiz
Rating: 84%, 1898 votes
bmwri... indicated that his solution for
C64 InkJet Printer Problem
is valid for all Printers
The best way to save money using inkjet or bubblejet printers is to refill your cartridges yourself. OK the manufacturers of the printers say not to use inferior refill inks but they are just trying to keep you buying their overpriced cartridges. Refilling a Lexmark Black cartridge could cost you $6 when buying a new one costs $60.
Follow the instuctions which comes with the refill kit and if supplied use the plastic glove supplied. I refill my own with the office printer and I usually get five or six refills out of a cartridge which saves me a total of around $250 to $300.
Another way is to buy generic cartridges off Ebay. My Canon Pixma 4000 costs me just on $100 for a full set (5) black and colour cartridges. On Ebay I purchase Generic kits at $88.00 for 10 packets of 5. That includes freight too. Saving me a whopping $900.
There has been no deterioration in my prints and the printer works as it did when I purchased it.
BMW
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
Helpful)
Phoebe
Rank: Apprentice
Rating: 0%, 0 votes
Ink jet printer prices have dropped dramatically, but the price of ink can be overwhelming. Printing in draft mode can save quite a bit of ink and money. Click on Start, then Settings, then Printer. Click on the name of your ink jet printer. Then choose Properties from the menu at the top of the page. Look for the tab that indicates the quality of the print, usually labeled Document/Quality. Choose the lowest quality available. This is often called Draft Mode or Quick Print. Although the print quality will be diminished, it is usually adequate for most everyday paperwork. If you want, you can also set the printer to print only in black to save on the more expensive color ink. You might want to consider making the draft mode and back ink only your default settings. Whenever you are preparing documents that need a more impressive look, you could specify the high quality print settings.
Was this helpful?
Yes
No
Solution #3
posted on Jan 17, 2006
Somewhat Helpful)
jarabito
Rank: Apprentice
Rating: 80%, 2 votes
jarab... indicated that his solution for
LaserJet 6p Printer Problem
I suggest to use the excellent Fineprint software, that print 2 or more pages in one...
Was this helpful?
Yes
No
Popular Solutions for Nikon COOLPRINT Thermal
Questions and Unsolved Problems for Nikon COOLPRINT Thermal
Do you recommend Nikon COOLPRINT Thermal Printer?
Answer
Answer
it says i have to download a high speed usb controller for my wireless usb adapter for it to be... (More)
Answer
On IMac OS 10.4 The printer gave me the choice of printing both sides. On )S 10.6 that choice has... (More)
Answer
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
