Question about Philips 55PP9363 55" Rear Projection HDTV-Ready Television
Home theater problem
My Phillips 55 inch rear projection TV started showing a split horizontal scrren with identical pictures in both screens. It is hooked up using pbr cables from satellite box to TV. Satellite feeds are fine in all but AV1 setting. DVD player & speakers run thru a reciever with the reciever hooked into the AV 1 TV outputs using rca cables. How can I get my picture on AV1 back to normal?
  • Roy Lonsinger
    Roy Lonsinger Dec 27, 2008
    Found the problem. Cable went bad. Replaced and all is fine again.
ctf1800
  • 4402 Answers
SOURCE: Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Posted on Dec 02, 2007
SOURCE: scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have had this problem in the past with Comcast. You need to go into the Power off menu (hit menu with the power off on the cable box) change the resolution to 1080I. Good luck.
Posted on Dec 30, 2007
Slinteriors
  • 8617 Answers
SOURCE: I have a phillips projection
No the red tint is either the red crt needs to be turned down or the red crt is developing a short. But hooking cable to it is not going to help, Unless the TV is really cheap, be careful as a new CRT will cost in excess of 300.00 and will have to be installed and properly aligned.
Posted on Jun 17, 2008
ginko
  • 19396 Answers
SOURCE: Phillips 55'' rear projection tv model #55pp970104
That is a convergence problem, it may be because of a faulty defective IC.
Posted on Feb 09, 2009
Slinteriors
  • 8617 Answers
SOURCE: Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Posted on Jul 25, 2009
What powers the picture tubes in a 55 inch model tn55x81
The tubes in the projection set among other things need: 200 volt screen source, filament voltage and high voltage.
Note that if set for example has a loss of vertical or horizontal sweep this will be detected and the tubes will be shut off to prevent the tubes from getting a burn mark on their screens.
Nov 06, 2012 | Toshiba TN55X81 55" Rear Projection...
Rca big screen 55 inch home theater
Please reply to this post with your model number and I will try to assist you. Your flyback sounds like its getting ready to arc out. Common problem with RCA TVs.
Jul 11, 2008 | Televison & Video
Phillips Magnavox 60 inch tv
not showing a picture are making a sound.
Jul 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
Screen missing
you will need the replacement screens. Phillips doesnt make them anylonger, they are exspensive. But you can get one by leaving a email at the following link with the model number of your set and what youre needing.
http://servicemanuals.vstore.ca/
Jul 03, 2008 | Philips 55PP9401 55" Rear Projection...
Phillips 54 inch rear projection,no picture.
One thing that comes to mind when you say high pitched sound is the HOT ( Horizontal Output Transistor). You may be able to find one at fry's electronics. They are pretty cheap. If you are handy and know something about electronics you may be able to replace it. I am not a TV tech, I have a background in electronics and like to play with them from time to time. Not sure this will help but good luck
Mar 18, 2008 | Televison & Video
Samsung hcl552w picture leans in on top and bottom
bad convergence ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 09, 2008 | Samsung HCL552W 55" Rear Projection...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Distorted picture
It seems you have a loose conection in the Horizontal deflection circuit,I will start checking the horizontal driver transformer then any overheated areas in the power supply and overall chassis.If you are familiar with tv service you know where to look but if you are not be safe and call for help,try no to use the set or the problem will be worst.
Sep 26, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Philips 55PP9363 55" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
