Clicking noise on he3t
He3t makes clicking noise during cycle, I think mainly spin cyle and sometimes certain codes come up. We have cleaning the filter at the botttom. could it be the drain pump?
I have the same problem. the clicking seems to be oming from the black box next to the filter.
Posted on Jul 17, 2009
Softener tray is not draining during wash cycle
This tray empties during the spin cycle not wash cycle. Is the agitator spinning during the spin cycle? If so, you are getting softener on clothes during this cycle as required.
Feb 17, 2015 | Kenmore HE3T Washer
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
Mar 10, 2011 | Kenmore HE3T Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore He3T will not pump out water
no. you have caught your pump going out on you and from problem description, go for it change it out.
Mar 29, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
What causes the HE3t washer to stop in spin and rinse cycle?
Sometimes the unplugging helps, or hitting "Cancel" several times.  Guaranteed to work though is to remove top, reach down the top to the door lock.  (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door.  This can also be accomplished by removing lower front panel and reaching up to do the same.   BTW, while in the top, make sure all the electrical connections are tight.  I found some loose before, probably from the spinning action.
Dec 06, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
