Question about Samsung BlackJack Smartphone
Can't get signal, but did, on my blackjack II
Phone cycles thru bad signal to no signal at all. used it all day, no prob, got home last night, won't work. rotates thru 3G to G to E to Emergency. figure it's an antenna problem, bought the refurbished phone instead of new. didn't drop it or dunk it. any guesses? can i get to the antenna and check connection? thanks.
  • katieroo1980 Jan 01, 2009
    I have the same problem, but mine was a new phone. I can't get on the Internet because it won't stay on the 3G network, only antenna. AT&T customer service told me I may have to talk to Samsung to get an upgrade to the operating system.
Basti
  • 1447 Answers
SOURCE: Blackjack II MMS/Internet Configuration
You can try this,
***First Step***
1.Main menu –> Select Services
3.Select Data Account –> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to WAP@CINGULARGPRS.COM (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back –> Select Back
***Second Step***
Select WAP
1.Select Settings –> Edit Profile
3.Select the first entry –> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to WAP@CINGULARGPRS.COM
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
To access the net select Services –> WAP –> Homepage.
If it connects the Black [G] should turn Green
mms
Select Messages –> MMS –> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to WAP@CINGULARGPRS.COM (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
or this
***First Step*** AT&T CINGULAR
11. Save
***Second Step***
Select WAP
Select back or done
mms
Select Edit Profile
Select Done or Save
Hope this helps!!
Posted on May 03, 2008
SOURCE: How I can connect internet to my laptop using my samsung blackjack
I can find the windows folder, but theres no folder that says internet sharing... :-(
Posted on Jun 23, 2008
SOURCE: My blackjack wont charge
I did a hard reset because i was having the same problem with a new battery and a new charger. I took my sim card out first to prevent any possible data loss. then followed the following steps:
  1. Once the handset has rebooted to the Today Screen, enter the following code: *2767*3855#. The handset should display a message “Formatting- Please wait a moment”.
  2. The phone will reboot after the Full Reset as this is normal operation.
after i did that i plugged in the charger and it worked perfectly. this is the last step that you would do after updating the software on the BJ
Posted on Jul 11, 2008
SOURCE: unlock code for blackjack II
To unlock blackjack ||,You have to connect your phone with pc and formate its OS.so you will get your phone unlock.
Posted on Oct 28, 2008
SOURCE: blackjack II
I had the same problem and I just got it fixed today. You need to backup anything you have on your phone then reset the whole thing. Here isthe link: http://www.wireless.att.com/support/tuto...
Hope this fixes your problem, so far it has fixed mine.
Rachel
Posted on May 21, 2009
My battery died last night when i got home i plugged it into the charger all night now it wont turn on
The phone might have shut off due to some errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Also please check the voltage on your adapter, check the battery, swap with a working set .Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Feb 18, 2011 | Samsung BlackJack II Smartphone
My blackjack ii just stopped working. I turned it
IT sounds like a software glitch.
the phone will most likely need a hard reset to repair it.
Sadly this will delete all of the personal data on your phone, and reset the phone to its factory defaults.
To perform a manual Hard Reset, press the Up Navigation key and the (Power) key.
Oct 24, 2009 | Samsung BlackJack II Smartphone
I got cut off the last session I hope I wont be charged again. I need to connect my blackjack II to my laptop via bluetooth I see my phone on the list but when I connect i get an error that the remote...
just reinstall your phone on your laptop. first you remove the device from the bluetooth devices. and reinstall it using the passkey. if you are already using it you should have known this process
Jun 13, 2009 | Samsung BlackJack II Smartphone
Contact info on Blackjack won't sync with home PC?
you probably need to reload the drivers for your phone onto your computer.
Here is a link to the samsung download center. choose your provider and phone and click
http://www.samsung.com/us/support/download/supportDownMain.do
Once the drivers are loaded it should hook up and communicate with your phone.
Jun 01, 2009 | Samsung BlackJack II Smartphone
Blackjack II
If you have the USB cord you can do it thru active sync. Here's a link for the users manual for your Blackjack...
http://www.cellphones.ca/upload/manuals/samsung-617i-blackjack2-manual.pdf
Good luck. If this helps you please rate this, thank you kindly.
Jan 30, 2009 | Samsung BlackJack II Smartphone
I dropped my blackjack 2 smart phone and the battery popped out, then a sqaure sticker in the back of the phone turned a red color and now it wont turn on.
well for the sqaure sticker thats a moister indicator, when this is red this means that the phone as been in or around water. SO the phone prob got wet at some point and thats why the phone will not turn on die to corrosion ,
Dec 08, 2008 | Samsung BlackJack II Smartphone
Blackack II unlock code
Hi
I have the blackjack II i617, the code is - put in sim card that you are going to be using the #0111*59428207# or just put in 59428207.
hopefully this work for you.
Jul 17, 2008 | Computers & Internet
Samsung Blackjack II Screen Stays Black
I have a solution. Call at&t. they will send you a new one. I have had my phone for 5 months and it happened to me also. There's a warranty on the phone itself that covers it from the day "you" started using it. I bought mine from a friend. Cool!! It should be here in 5 days free shipping.
Blackjack II Geek.
May 18, 2008 | Samsung Blackjack SGH-I607 Smartphone
Samsung BlackJack Smartphone Logo
116 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
