Question about JBL GTO1202D Car Subwoofer
15" JBL Sub
Well i had a 15" sub and whenever iturned it up it sounded like ****. So i talked to my buddy and he said that it wasnt getting enough power to the sub. So i went out and bought a 400rms pioneer amp. I turned the gains down to about 25% and i turned it up. Well now it sounds like its just punching the sub. Theres no sub sound in it anymore. Its like someones hitting it from the back and it sounds like ****, i dont know what to do. Please help!!
  • alexthegr319 Dec 20, 2008
    Thanks dude!! i just went and bought 15" fusion sub for it so that should rock pretty good:)
    Problem Solver:
  • 8 Answers
That is a compleately stretched voice coil my friend
only thing to do is take it to where you bought it for warantee
or purchase a sub that will be effiecient in the box you have
also there could be a chance that your impedence is not matched for the proper amplifier output
what is the resistance on your coil or coils
Posted on Dec 20, 2008
  • Derek Nott
    Derek Nott Dec 20, 2008
    ohh and make sure you can not move your ground connection with the force of your hand and that there is no paint between the terminal and the body
12 inch sub(JBL) in box with a 500 watt pioneer amp, sounds good with some types of base. would you cut a port hole in speaker box?
riverray1969 it would help if I knew the exact model number of that JBL sub you are referring to. With that info I can provide exact specs.
Basically, you need to build/modify an sub enclosure that is suited for the sub, the music you mainly play, and vehicle tuning. Generally, sealed enclosures will provide tighter bass response and get decently loud. Some would argue that it will give you greater sound quality. A ported enclosure will give you a louder more booming sound. That depends also on where the port is tuned (ex. 32 hz, 36 hz, etc ). You need to make sure that the enclosure meets the sub's airspace requirement as well. A customized well made enclosure is just as important as the sub you put in it.
Oct 16, 2012 | JBL P-1020D Car Subwoofer
JBL JRX118SP POWERED SUB. Getting power and signal light flashes when theres a signal. Just no sound??? Speaker/coil looks fine..
There's a 8-pin ic located right at the side of output devices & power supply filter caps, that is a common issue with JRX active subwoofers, hope it helps.
Jan 29, 2012 | JBL JRX 115 JRX115 15 JRX118s 118s Speaker...
Jbl eon g2 not giving any low sounds only tweeter works
open it up and check cables leading to sub (large speaker) they're notorious for falling off - getting banged around
Feb 17, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I have a powered sub woofer, i noticed it started to make scratching sound or popping, then i noticed it wasnt on and had a red light on the back instead of a green light. I turned it off for a hr and...
This item needs to be repaired - shorted or bad parts on board. See Ebay for Repair of JBL and Infinity Amps - Specific Models - Search - Be Happy:)
Jan 03, 2011 | JBL Venue SUB10 Subwoofer
Subwoofer will not product sound. (ignore product)
Please verify that we're talking about a JBL PSW-D110 here. I'm making no assumptions.
Are you running the Ipod into its L & R RCA jacks as prescribed?
Have you tried it with something besides the Ipod? A sub isn't supposed to reproduce a full range signal. Come to think of it, is the Ipod even outputting anything within the sub's operational range? I don't expect a lot of real bass comes out of one.
Perhaps you could try adjusting the Low Pass up to 180 to see if anything anywhere near the 'real' bass region is present.
Bottom line: There's not a lot of need for a sub (and no other speakers) running off of any music sound source. You wouldn't hear anything above 180hz.
Nov 28, 2009 | JBL PSW-D110 Speaker
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 02, 2009 | JBL PB12 Subwoofer
Jbl 15" sub
umm. i think you having some driver problems. how many watts you put it? do you have a filter? if you have one install it or turn it on. lets see what happends.
Nov 10, 2008 | JBL GTO1202D Car Subwoofer
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenter™ SW 200 with Clean Power™ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
JBL GTO1202D Car Subwoofer Logo
137 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Morne Olivier
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
