Question about George Foreman GR30 Indoor Grill
LED timmer The LED timer on my grill sets itself. I can't get it go down, it goes up all on it's own!!! How do I fix that???
  • 105 Answers
Check to make sure the 'up' button is not stuck. There is nothing more you can do, as there are no user serviceable parts in this unit, & the problem is either a stuck button, or a faulty timer module.
Posted on Jul 17, 2007
SOURCE:
My Sharp LE820 Aquos LED TV recently auto turn itself off, when I turn it back on, a few good 10 minutes or so later it automatic turn itself off again.
Please check that the sleep timer did not somehow get set. If it's not the sleep timer, check if the panel stays ON longer after it's been off for awhile to cool down. Possibly a heat problem with the power supply or main board.
Jan 15, 2015 | Sharp AQUOS 52in. LE820 LED LCD HDTV
Dryer knob willnot advance back to off position on left side of timmer. I allready changed the timmer. But did not help.
Check and see if you wired it correctly. This is odd though. The timer actually engages the current and creates a continuous circuit until cycle is finished. There may be a physical obstruction keeping the knob in place. Check all this out and if still no luck , let me know and we will dig deeper.
Mar 11, 2013 | Dryers
Sony trinitron wega ( comes on by itself and goes off by itself ) could you please let me know what it needs thank you
Thanks for posting to Fixya and it is my pleasure to guide you.
Sounds like a timmer has been set to me. My TV did that once, at 3am, and I had set the timer without knowing it when I went through the setup.
Check in the setup and look for the timmer and it is turned off.
Good luck and please post back that you are successful and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Sony Televison & Video
Dryer timmer stopped working....electric dryer, bell still chims when you turn the timmer to off but when setting the timmer it never moves.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 31, 2010 | Kenmore Dryers
Timer keeps going off
push in timmer knob turn till its at 12 o clock if it does not shut off then the timmer is bad ..you can dissconnect timmer from the back ..turn off breaker or unplugg. dissconnect wires from timmer .. tape connectors real good .now no annoying buzz
Aug 22, 2010 | General Electric Stove/Oven/Range Chrome...
Ecoplus Digital 120v Timer Dual Outlet 24hr 7day Timer: my timer is not cutting on when i have it set to....
Make sure your timmer is set to "AUTO" mode and that your programed times/weekdays are good, resetting the timmer should solve your issue i've had it before, these timmers do this to me once and a while.
Make sure you dont have an "O" on the left of your time as this randomises off/on times by 2 to 32 mins. Press "HOUR" and "MINUTES" at the same time to toggle this option.
the timers manual can be found here:
Eco Plus Digital Timer
May 18, 2010 | Day-Timer Ecoplus Digital 120v Timer Dual...
Timer does not move in Auto/delecate
Im guessing there is another thermostat in the circuit to actuate the timer motor circuit. If you can find the timer motor wires check for voltage in the run (cycles yuor having trouble with) modes. Automaticadvance timmer mode is usually an open set of contacts and close when the element is heating too correct temperature allowing power to continue to the timmer motor. In the delicate cycle often it is the same thermostat on a differant set of contacts (but they could be on the same thermostat this type of thermostat has 3 termjinals usually 2 on 1 side and 1 on the other). that energize the timer motor.
The other thing that could be the problem is the timmer itself. There has to be a set of contacts inside the timmer that energize the timer motor in both cycles. these are or can work on some cycles but not others due to worn out parts in the timer. Check for voltages her that corrospond with your timer motor.
Hope this helps Please rate me accordingly and GOOD LUCK
Mar 08, 2009 | Amana ALG443RAW Gas Dryer
AE-1 self timmer
The battery is not the problem. It is more likely the the internal switch has failed, (always stuck on self timer). The switch is a ring around the release button for the shutter. The small black tab covers the red LED in normal release mode, the self timer is on when the tab is facing forward.
Jun 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
Defrost timer
The timer has a rotation 24/7 every 6 to 8 hrs. depending on timmer set up it goes into defrost... there is No way to adjust when it will defrost.
Sep 19, 2007 | GE (GTS16BCS) Top Freezer Refrigerator
George Foreman GR30 Indoor Grill Logo
114 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Thomas F. Schneider
Mike
Gerry Harvey
Gerry Harvey
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
