Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Connection problem Ok, I have everything plugged in, and the computer that is wirelessly connected say it has a local area conection, and that it is connected to the D-Link, but I cannot acess the internet and when I go to Network on my computer, it says that the router isn't connected into the internet. It all started after I unplugged it from the wall by accident, then plugged it back in. everything is in the right spots they were before when it worked, but it isn't working now. What do I do?
  • mica_gneiss Dec 29, 2008
    I had similar problem when I try to set mine up a year or so ago. If you are with Rogers as an internet provider, their self healing software is not compatible with the D-Link software. I ended up removing the Rogers and D-Link software from my computer. Re-establish the LAN, I had to reload the Rogers software then remove it. I think the important step is to remove the Rogers software before you load your D-Link. If you are not with Rogers ... this probably wouldn't be any help. D-Link also have a 24 hour help line.
  • 49 Answers
The configuration on your Dlink may have been corrupted when the power was lost. Try to reconfigure your DLink router internet connection and your wireless network setting on the router.
Posted on Jan 04, 2009
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
When I type in the IP Address for the DWL 2100AP, which is 192.168.0.50, nothing happens, it is not available??? What do I do?
go to my network places right click then properties internet protocol tcp ip
put this 192.168.0.66
255.255.255.0
ok
when the local area connection is conected go to your explorer then type 192,168,0,50
Oct 23, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
Its a geforce6100sm-m reformatted and now its telling me info Network connection: Name=Local Area Connection 2, Device=USB Cable Modem 351000, MediaType=LAN, SubMediaType=LAN info Network connection:...
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Sep 21, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Can not connect to the internet
check your firewall setting.
check if your connection is working or not, by connecting to other pc if possible.
check if dns etc config for your internet is ok, for this you must call you ISP and check if there are no issues with you connection.
showing connecting cant mean actually connected, it wont work unless confuguration setting are good.
Mar 12, 2009 | Computers & Internet
My computer cant find my router
  1. Make sure your network cable from the modem to the router is good and connected to the uplink port
  2. If connecting directly try other port
  3. Check local area connection properties
  4. Double click "local area connection"
  5. On the middle box find and highlight "Internet Protocol ( TCP/IP) and click "Properties" button
  6. Make sure "Obtain an IP Address automatically" and "Obtain DNS server address automatically" are the only ones checked and click "ok" button
  7. Make sure "ethernet card" is NOT disabled
  8. Update ethernet card driver if necessary.
Wireless:
  1. Turn wireless switch on
  2. Check wireless connection properties and that Internet Protocol TCP/IP configuration is similar to the above
  3. On wireless properties select "Wireless Network" tab and Add your SSID (wireless network name) if not there and if there Move "Up"
  4. Update wireless card driver
Router:
  1. Double check to see that "Automatic Configuration" DHCP is selected
  2. Double check to see if "DHCP"server is enabled
  3. Check wireless network mode and select correct mode
  4. Check wireless channels and adjust as necessary
Jan 18, 2009 | Belkin (F5D7230-4) Router (587009)
My router is disconnected to the internet connection everyday
I know how you feel, it happened to me too.
Ok what you need to do is exit out of everything, look at the bottom where the line is blue. There you would see one computer and two computers. One is for a Yellow cord, which is for a Local Area Connection, and the one with the Two Computer is for your wireless connection, if you dont have a Wireless connection computer, then go to start , then go to Set Program Access and Default , there you can start a new connection which will co
Jan 11, 2009 | Linksys WRT160N Wireless Router
About my wireless card...
reset the network settings both on the computer and your router and start again. go to the website for your router and enter the ip or mac address for your wirless card and enable it on your network. to get your computer to recognise the network, turn off wireless, plug it in the local area connection first then for a few minnutes then enable the wireless and unplug the wire and it should recognise.
Jun 23, 2008 | Computers & Internet
I can not get on line
When you plug in the network cable, ensure it is plugged in correctly to the network card and into one of the router's ports at the other end. The LINK light should light up at either end (computer end and a tthe router) and flash when data is being sent or received. Then on your computer, (for Win2000/XP) go t Start, Settings, Network connections, "Local Area connection" for your card, then click on "Properties" then scroll and double click ''internet protocol' then select obtain ip address automatically. this will assign your computer with an ip address given from the adsl modem. all other settings will then assign automatically as well which should give you access to the internet thereafter. What you could also try is from one of your working wireless computers / laptop, see what IP address and gateway addresses have been assigned by the DHCP host (automatic IP address assigner), to helpyou work out where the address is coming from, it should be coming from the adsl modem. check your address by going to Start, settings, network connections, local area connection, then click on the support tab.
Apr 02, 2008 | D-Link Wireless
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
171 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
