Question about Watches
Colibri lighter My Colibri sensatron lighter will not work , put gas in - no leaks, open to light still no sound of gas, spark is working fine.Would like to know how to get inside to find the problem
  • 6 more comments
  • Jasonoram Dec 21, 2008
    Hi there, yes there is a screw at the bottom which i have undone. I can then undo the filler valve /flame hieght adustment
    Hi there, yes there is a screw at the bottom which i have undone. I can then undo the filler valve /flame hieght adustment and take out the battery then there is no visable way to remove any other parts that i can
    Hi there, yes there is a screw at the bottom which i have undone. I can then undo the filler valve /flame hieght adustment and take out the battery then there is no visable way to remove any other parts that i can see.
    I am
    I am reluctant to
    I am reluctant to stick
    I am reluctant to stick it
    I am reluctant to stick it in a
    I am reluctant to stick it in a vice
  • 2,334 Answers
Usualy there are screw at the bottom.
If there are no screws at all. that means the lighter is assembled in 'click-on' way and you have to use your imaginary engineering skills.
Start with a part which looks attached to lighter the last.
Posted on Dec 21, 2008
  • Arturs Kalnins
    Arturs Kalnins Dec 21, 2008
    If you get that far, try to extract ignition part. Then there should be a flame regulator. Unscrew that fully and give it a very good clean with lighter fluid (ZIPPO).
What type of battery I need to buy for Colibri touch senzor lighter ( model 70-80s )? Thanks
they do not have a battery when they quit you throw them away and buy a new one
Apr 30, 2016 | Colibri Watches
I have a model 35002 triple torch Colibri gear lighter and I need instructions on how to refill it with butane.
There is a small nipple on the bottom of the lighter. That is where you put the canister on to refill.
Dec 12, 2015 | Colibri Watches
I have a dunhill lighter pat. #3910750 des. pat. #235456. When I fill it with butane, it leaks out of the top of the lighter. What is causing this?
Sounds like the valve that regulates the gas flow is sticking in the open position even when the lighter is not in use. Try spraying a light machine oil like WD40 on the gas jet aperture and any other moving part whilst your at it. Wipe excess oil from the lighter and leave for several minutes for the oil solvents to evaporate. Light the lighter a few times in rapid succession to enable the oil to penetrate. If the oils done it's job the gas should no longer leak.
Jan 02, 2014 | Watches
Colibri cx gear 35002 butane lighter
I.ve got a lighter its silver crome alluminum it reads on both sides a big X with a c on top and us on bottom its butane on the bottom it has a signiture I.D it looks like a snake going up a stick can you help me idenify this lighter it's driving me nuts Thank You Lily
Sep 22, 2012 | Watches
What battery to put in colibri sensatron lighter
303 or 357. when you take old battery out it may be diffrent number need to convert number / use retna battery chart
Feb 01, 2012 | Watches
Battery required for colibri lasertron lighter
This lighter would normally use a CR1240E-T lithium 3 volt battery. If you still have an old flat battery, it can be charged if you know what you are doing. OK, so you don't have an old battery, so there are 2 types of battery that you can use to sort the problem. A lot of advice out there suggests using a CR1225, with a little packing to make up for the lack of thickness, this I have found barely works, as the capacity is so low to start with. And now for the real solution........ I use two silver oxide 391 batteries (11.6mm X 2.1mm @ 1.55volt each). With bits of paper to insulate the positive poles from shorting, and more paper to insulate the screw down cover from touching the top battery. The whole thing takes only a couple of mins, and you'll have months worth of bright red light and powerful sparks. Good luck John P. sylvie44@btinternet.com
Feb 21, 2011 | Colibri Watches
My problem is that i can't find an postal or email address for somewhere reliable that i can send my old colibri 'molectric' cigarette lighter for repair. can anyone help? this lighter has great...
mcdevito75 here, Hello Dave, My advise is to take your lighter to a jewelery shop, you can try a small place, they may have the info or even repair your lighter. Also try Colibri watches.com try and see.
Feb 11, 2011 | Watches
Watches Logo
1,037 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
