Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Beater bar on Dyson upright won't turn when handle is lowered
When handled is lowered fo vacuuming beater bar will not turn and suction doesn't seem right. When vacuum is running in upright position suction is OK at top
  • 6 more comments
  • loopup Feb 09, 2009
    When vacuum is upright there is no suction in lower part of unit. When handle is lowered for vacuuming, suction is redirected to lower part and beater bar should start turning. I called Dyson and rep there was very helpful in assisting me however she ultimately referred me to factory authorized repair center in my area who was able to effect repairs. If you call Dyson you'll need the unit serial #(they can tell you where it is on the machine if you don't know)and if you purchased the unit less than two years ago it is under factory warranty and Dyson will pay for repairs. If you didn't fill out and send in warranty card when you purchased vacuum they will take you at your word concerning date of purchase. good Luck
  • Anonymous Feb 09, 2009
    The beater bar wont turn and the sucktion doesnt seam as affective
  • Louis 335 May 11, 2010
    there is no suction when the dyson is in the upright position makes funny noise kindest regards louis
  • Anonymous Mar 20, 2014
    Meile upright vacuum has poor suction with no obvious clogs that are seen easily
  • Anonymous Mar 25, 2014
    Beater bar cuts off whille vacuumi
  • Anonymous Mar 30, 2014
    How do you remove the beater bar motor to a rainbow vacuum
  • Anonymous Mar 31, 2014
    beater bar spins, vacuum motor not running
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Posted on Jan 01, 2009
  • StevenPU Apr 22, 2011
    I replaced the very thin wires (#18 or smaller) and gromet with some #16 "Monster" speaker wire in jacket I had left over from wiring a media room. The cable is almost the size of the power cable on the Dyson and the jacket will protect the wires. 2 crimp on connectors on each end and the fix was done. Thank you very much for leading me in the correct direction.
    Problem Solver:
  • 8 Answers
You need a new belt and maybe a new brushbar.
Posted on Dec 23, 2008
    Problem Solver:
Turbo bar on DC15 not working.
Posted on Jul 22, 2010
How do I fix the suction on my Dyson vacuum?
check the pipe is saying that is clogged with something who knows lots clock that pipe make sure all pipes from your vacuum is is unstuck are clogged.
Nov 29, 2014 | Dyson DC65 Animal Complete Bagless Upright...
My dyson beater bar is spinning but no longer touches carpet surface to pick up hair or thread .There is still plenty of suction. If I ever so lightly place my hand on the top of the beater brush it works...
Brush rolls wear out and usually need replaced every few years. The DC33 model has a clutch with belts which could also be slipping. I would replace both of them
Jan 05, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
When the dyson is turned on the suction goes to the wand when you tip the beater down you do not have as much suction you cant pick up lint.
The Dyson system is designed to operate the hose with the handle in the upright position. When the head is tipped down (floor vacuum position) it closes the opening to the hose/wand
Nov 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Placing the handle of my Dyson DC07 into its upright and locked position causes the beater bar to stop turning. It will not start turning until the handle is first lowered to the working position and the...
Hi its Darran at Dyson.
The brush control is designed to switch the brush bar off automatically when you stand the machine back into the upright position. It is designed this way to protect any delicate floor surfaces when you have the machine switched on and upright and when you are using the hose.
If the brush control should be in the centre position and move forward to the "on" position when you release the head. If it is not doing this, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Feb 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction when using the hose.
The beater bar is supposed to stop when the vac is upright. Sounds like you have a clog. There are several access points to check, fairly easy to clear obstructions.
Nov 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My beater bar will not spin when the handle is lowered? But there's suction thru the hose when the handles upright
The motor that spins the beater bar is connected to a tiny switch, if that switch is not operating that could be the problem. If the motor is not spinning, that could be your problem (seized), or if you have a broken belt that could be your problem.
Hope this helps
Sep 25, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Oct 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
4,113 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
