Welcome-
have you tried reinstalling the drivers for the printer? sometimes the drivers mess up and they need to be reinstalled. if you get me the make and model of your printer i might be able to find you the most update drivers.
tom
Hi Sharon,
These are the possibilities:-
1. The ink has leaked inside and not letting the circuitry to respond properly-For solving this take out the tank and clean it , if possible check for leakage inside the printer and clean that also
2. Ink tank is empty you have to change it.
3. The firmware inside the printer has gone bad and need to be reloaded/repaired by a qualified technician.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Might be installed ink tank has not enough quantity of ink in it thats why printer give error.
Install new ink tank, available in ebay with 15.49 only.
Check the ink tank contacts and clean the connector, if there is ink on them, that can be the cause for the error message.
Try cleaning the connectors on the printer carriage, if this does not help it is because the 5 PGBKchip had been reset, and you need to replace it with an original cartridge.
Unfortunately many manufacturer do this to stop the distribution of other brand cartridges.
When that happen there is still ink inside, you need to use a chip resetter on the ink tank to have it working again.
I did clean the connectors but the problem still is occurring.
the ink well is 3/4 full and I hate to waste the ink that's why I have not purchased a new one .
My tank is 3/4 full and I hate to waste all that ink. So far I do not have a solution.
Actually, none of those possibilities worked in my case. I have found out that possibly the tank has gone bad. Thank you for your comments though.
