Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
I have a Frigidaire refridgerator with a filetered water and ice maker system. Recently we discovered that there wasn't any water coming from the water filtration system and no ice was being made. I finally got the water to work by changing the filter and making sure the Household and and Saddle water lines were on. After all that, I noticed that there was air, no, it actually looked like there the water wasn't fully going through the ice maker water line. I figured it might be because there was something wrong at the Ice Maker Inlet value or that there was frozen ice clog coming through the tube that fills the well. Sure enough - there was frozen ice in the tube, I think because there wasn't any water flowing through the fill tube. I finally melted the ice with a blow dryer and the ice slid out. Yet, the water still did not come in. Onto the ice maker inlet at the bottom of the applicance. I unscrewed the inlet only to find out that there wasn't any water coming out. Yet, there is water being fed to the water filter. I think I narrowed down the issue to the ice maker inlet valve. What do I do next? Same Problem with my Frigidaire FRS26znh
  • 700 Answers
Take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Posted on Dec 20, 2008
2 Suggested Answers
the dr
  • 447 Answers
SOURCE: Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
Newly installed ice maker two days old, not dropping ice, frididaire refridgerator
Ice maker under warranty have them look at it will not cost you anything.
Aug 29, 2014 | Kitchen Appliances - Others
My Frigidaire side-by-side refrigirator is not making ice
Here is a simple tip that may help you decide what is causing this problem. If the ice maker has no ice cubes in the slots fill with tap water and allow water to freeze. If the ice maker cycles and drops the ice into the ice bin and then does not refill with water the problem is the 241734302 Water Inlet Valve (providing that the model number above your post is correct) If the ice maker only sits there with ice in the slots and does nothing the ice maker is the problem 5303918277 Ice Maker Assembly Testing the water control valve is as follows. I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 26, 2013 | Frigidaire FRS26H5AS Side by Side...
Leaking water in side always
If the water leak is down the back or ctr its the drain line going to the underside of the fridge. If its down the side where the ice maker is its the ice make is not level if no ice maker your tray under the freezer may be leaking instead of draining.
Jul 20, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
Ice with Sediments
in the water supply line to but well before the refrigerator fit a ceramic water filter
that has a filter so fine that many germs cannot pass through
Nov 26, 2017 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Sep 25, 2007 | Daewoo FR-064R Refrigerator With Ice Box
Jenn air model JRSD209T
If you have a cold enough temp in the icemaker a heater should then kick in to warm the plate and a motor then turns and drives the ice out. The ice maker modules can be repaired, but the checks need to be carried out by fridge guys. Alternatively you can replace the whole module but this can vary in cost quite dramatically. Hope this has been of some help.
Sep 11, 2007 | Frigidaire FRS23H7C Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
497 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
