Question about Canon PowerShot SD550 / IXUS 750 Digital Camera
No memory card message
Turned it on one day andthe no memory card message came up, card was in and i have switched cards still says no card. the cards work in other cameras so its not the cards, what to do?
    Scholar:
  • 121 Answers
Check to see if any of the little pins that make contact with the card may be damaged, bent, broken or dirty. If you shine a light in there you should be able to count them. compare to the slot in a different camera where you know it works. If it's only bent out of shape you might be able to bend it back, but it would probably void any guarantee you might have left.
Posted on Apr 03, 2007
Canon PowerShot SD400 No memory card message, but there is a memory card installed. Tried multiple memory cards and got the same message. Made sure the memory card was locked.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. By the way, if you're using 4GB or larger SDHC cards, they won't work with the SD400 as that camera was made before SDHC came out. Consider 2GB or less standard SD cards only. They're very inexpensive these days on Amazon..
Dec 27, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
I have just installed a 4 GB Sandisk in my new Kodak Eash Share C195 camera and it keeps giving me an error message - "Memory card is protected, Reset switch on memory card" I saw only one switch...
Deb,
A couple of things you might want to try the little lock on the side of the memory card should be in the unlock position. If you are still getting the error message then shut off the camera and remove the battery and the memory card. Insert the battery after about ten seconds should and install the memory card then turn the camera back on. Format the card in the camera NEVER format the card in your computer, format the card over deleting single images. If this camera is new, new then you should have the instruction manual or may be called the owners manual look for formatting instructions, every digital camera has a format feature to clean the memory card. Now if all this still doesn't work you may need to update your camera software. My Canon Pro camera gave me a headache when I went from a 4 gig to an 8gig card it just wouldn't acknowledge I even had a card in the slot. However you may just need to hard boot it after switching the memory card to the unlock position. Don't forget to format the card. Robert
Dec 17, 2010 | Cameras
My Canon A460 says the Card is locked. The lock switch on the card is set to unlock. I have another camera with a similar card. Both cards work in the other camera. neither card will work in the A460 both...
back up your data first,thenyou reformat the memory card in the camera.i guess you have formatted the memory card in another device.canon cameras generally do not accept cards that have been formatted in another device.then sitch off the camera and reinsert the memory card.
Jun 27, 2010 | Canon PowerShot A75 Digital Camera
Samsung SL620 - - "Card Locked" message
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 16, 2010 | Samsung SL620 Digital Camera
4GB Lexar Premium 60 switch is up, but the message I get says
i have the lexar 4 gb memory card with a ton of pictures which i never deleted. when i put it in a card reader it wont pop up on the screen. it wont work in my camera it will say once i turn it on (card can not be accessed reincirt/change card or format card shows up on my camera screen.) this worked a few days ago and just stopped working randomly. help me
Sep 30, 2009 | Lexar Professional High-Speed 2GB Secure...
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
Optio E10
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Oct 11, 2008 | Pentax Optio S7 Digital Camera
Kodak C340 Memory card Formatting
The write protection is on the card (a little "pin").
Aug 15, 2008 | Kodak EasyShare C340 Digital Camera
Camra memory card says write protect
Same here. So just simply changing the card makes the message go away?
Jan 29, 2008 | Olympus Stylus 710 Digital Camera
"Memory card is locked
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
23 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
