Question about Whirlpool LGV4634JQ Gas Dryer
GGW9868KL0 SENSEON GAS DRYER Flame comes on but clothes not dry
I have replace 2 items, the internal bias Thermistor and High limit thermistat, #42 & 43 on the schematic. Clothes do not dry, flame comes on but off in about 20 seconds then comes on again but dryer doesn't get hot enough.
Can you suggest what it may be. Is there a sensor for wetness that may not be working.
Jeff
  • 640 Answers
Since you know your stuff and our exhaust is clear correct,,,change your gas vavle coils ..if weak they will shut unit down in a couple of mintues..
Posted on Dec 30, 2008
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
No heat from tumble dryer
Hi.
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
My 80 series electric kenmore dyer runs but no heat
MY dryer has no heat
** UNPLUG a dryer before attempting ANY repairs. Lethal!
A dryer heater is controlled by the timer, a thermostat and a high-heat safety switch. The thermostat and safety switch are mounted on the housing around the heater.
Most likely - If the heater is blown, a visual inspection inside the heater housing will see a loose heater wire.
Next likely - Thermostat problems occur. I replace the thermostat and high-heat safety if either are suspect. Cheap, easy fix.9df7975.jpg
Least likely - Controller failure. This can be expensive ($80 - $400) so consider if you want to spend the money. A controller is actually fairly easy to change. Buy a new knob as you are likely to break it without experience and special tools.
Apr 17, 2010 | Kenmore 62602 Electric Dryer
The gas dryer is not getting hot enough to dry clothes have to run it double the time to get clothes dry-exhaust not blocked-igniter is working-there is a flame-checked dryer heat setting manual knob with...
You might want to replace the thermacouplar. Sometimes when they are going out , all will appear to be alright but as you stated it takes a long time for the flame to come back on. This sounds to me like the thermacouplar is going out.
Dec 08, 2009 | Amana ALG331RAW Gas Dryer
How do I know which thermal unit is the one that shuts the dryer off when the clothes are dry? one's called a cycling thermostat, another is called a fixed thermostat and the third is called thermal...
Usually the Fixed Thermostat (also known as the High Limit Thermostat) and Thermal Cut-Out (TCO) are used in conjunction to regulate and protect the heating circuits.
The Cycling Thermostat (also know as the Internal Bias) controls the amount of heat required/desired to dry your clothes.
You need to remove the rear panel of the dryer to access the heating circuits on this model dryer. With the back panel removed, the heating circuits will be on the right hand side and the blower fan assembly is located on the left. The Hi-Limit Thermostat and TCO are located on the outside of the heater box with the Hi-Limit Thermostat mounted next to the heating element terminals and the TCO located at the opposite end of the heater box. The Cycling Thermostat is located on the blower fan housing next the Thermal Fuse. It will be the metallic round component, while the Termal Fuse will be a white plastic component.
For better clarification, you can view an exploded view diagram of your appliance at pcappliancerepair.com. If you type in your model number, all the parts I've mentioned are listed under Section 3 (Bulkhead Parts). The components are listed as follows:
Item 6 - TCO/Hi-Limit Thermostat Kit (both parts should be replaced at the same time).
Item 15 - Hi-Limit Thermostat (sold separately)
Item 23 - Thermal Fuse
Item 24 - Cycling (Internal Bias) Thermostat
If you are experiencing heating problems or longer dry times, please review the following link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the section that discusses dryer ventilation. The majority of dryer heat related problems and failures are attributed to poorly installed, clogged, or kinked dryer ventilation. If you haven't had the ducting checked in a while, now may be a good time to do so.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Sep 10, 2009 | Roper REX4634KQ Electric Dryer
Kenmore dryer runs but will not heat up
check the 2 sensors located in fron of the dryer.they are 2 black cylinoids..and usually have 1 or 2 screws...
Jan 09, 2009 | Kenmore 73952 Gas Dryer
Dryer won't dry
  1. thermostate 2 the gas valve cylanoids the 2 black things on top gas valve can be bad will heat then stop heating 4 awhile thay drop out dont open valve watch your valve listen 4 it if comes on run heat goes off dont come back on 4 awhile 3 5 min bad valve cylonoids
Dec 29, 2007 | Kenmore 64952 Electric Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
237 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
