Question about Ultra G-Technology G-Drive mini - 60GB Portable USB 2.0 Bus-Powered Hard Drive - 5400rpm 90902201
Hard disk not working
My Ultra 3.5: Mini Portable Disk just stopped working. Lights and fan come on as if everything is ok but it is no longer connecting to my PC ... any help is appreciated!
  • 198 Answers
Hello Bshannon, An external hard disk is composed of several parts. 1 the actual hard disk drive (HDD) 2 the buffer and USB interface 3 the power circuitry that must provide a +5 and a +12 Volts tensions. If the hard disk powers on is spinning and the light are on we could exclude the 3th option. There is a problem with either 1st or the 2nd options. Most probably 2nd. It may happened due to a power spike that burned out a buffer memory. It happens pretty often with these hard disk's or at least I've seen it often. However there could be other reasons for this and some of them pretty simple. Maybe a faulty connection with the internal components, USB jacks (the one on the hardisk) is the main suspect. Yes they fail just like that, the removal or a simply faulty contact on even one of the USB's 4 signal pins will result in not having the device detected. In any case I would recomand to have it checked at a service center because these small hard-disk are sensible to electro-static discharges and power spikes and you may cause some of that to them when you try a DiY check-up. If it can be fixed it woun't be expensive, if it can't (burned out buffer memory) .. no one will be able to fix it. However they could extract the actual hdd part from it, you could use it with a laptop (they use the same type of hdd's) or sell it. If you need more directions or have any other questions please reply. Good luck.
Posted on Apr 03, 2007
My hard disk hardrive dont read on my computer
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
hope this helps
Aug 15, 2012 | Ultra G-Technology G-Drive mini - 60GB...
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
Portable hard disk fell its not being recognised
The drive has failed, Contact the manufacturer for a replacement and if u need the data back, contact a data recovery company :)
Apr 14, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Can't install external hard drive. Do not have disc or manual. When I connect drive to USB port, drive lights up and makes sounds, but does not show new hardware.
Most likely the drive hasn't been initialized. Go to start, right click my computer, then manage. Select disk management on the right column. A window should immediately pop up saying disk initialize wizard. Press next, and it will guide you through on how to initialize the disk. Make sure you format it as well, so that the computer will recognize it as a drive.
Dec 29, 2009 | Maxtor OneTouch III Mini Edition 120GB...
1GB Micro Vault Ultra Mini USB 2.0 Flash Drive not formatting
1. Download this tool:
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Hp530 Ultra Slim starts and stop after 3-20sec
I have had this once before, and then it was one of the hard disk cables which was interfering with the fans inside the case. In my PC it was the PSU fan which was being halted. Try moving the cables around inside the case and ensure none of the corners where they are folded are protruding into any of the fans.
Feb 03, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Formated hard disk
Go to Computer Management
Then click Disk Management
You Will find Your Portable HDD without Drive Letter
Just Right Click and Assign a Drive Letter...
Thats all...
Jan 29, 2009 | Maxtor One-touch III Mini 40 GB USB 2.0...
Can't reboot Compaq/Presario desktop, (power supply is working)
If the system recovery disk doesn't work it usually mans that the hard drive is bad. I would change the hard drive and use the system recovery disk on it after replacement.
Dec 27, 2008 | Computers & Internet
Saying disk not readable
you could try a repartition / reformat, if the drive is detected at all, or you could try running scandisk/disktools, to try and recover / repair the TOC/ FAT
Apr 11, 2007 | Ultra 1 Bay USB 2.0 External Drive Case
Computers & Internet Logo
147 people viewed this question
Top Ultra Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Alun Cox
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
