I have a HP photosmart C7100 All-in-One.I can print photos & print "e"mails without any problems but I can't scan into my computor.One of the error messages is(The scan cannot be performed because another program or computer is using the network device.Try again later.)of coarse this is not the case.
    Sergeant:
    Habit-Forming:
  • 118 Answers
Its probably due to your software firewall. https://support.hp.com/us-en/document/c01806655 the link here is for the same error and shows steps to diagnose the issue and to try the scanner webpage. These days any network attached device(like your scanner) has an IP address and will present a webpage with Menus to you if you type in the IP address into a web browser. you just need to know the IP of the scanner/printer. you find that out by printing its network status sheet. you do that by holding in buttons and turning the printer on whilst holding in the right buttons until a sheet is printed. anyway have a look at the link. and check/change your firewall settings to unblock the scanner application.
Posted on Dec 13, 2017
3 Suggested Answers
SOURCE: Hp Photosmart C7100 All in
Do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :)
For me it works!!
Posted on Jun 21, 2008
comment
  • 78 Answers
SOURCE: We have a HP Photosmart
If possible, find the software disk that came with the printer, and reinstall. One of the options should be to scan from the scanner to the computer. Just make sure that option is selected on re-install, and that the necessary communication cables for that option are installed.
Posted on Nov 19, 2008
HP Photosmart C5280 No computer connection
mail or call to the technicale support team of hp for that problem and get the folloups from them every day, i cant say much more becouse its realated to mac and for mac there is too less data available on hp sites.
Jun 13, 2012 | HP Photosmart C5280 Printer
HP Photosmart C7250 lines in photos
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Jan 09, 2012 | HP Photosmart C7250 All-In-One Thermal...
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
Jun 05, 2011 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7100 - only 10% of page printer
If your printer does not print the entire page, it is probably because the print head is clogged. Try going to print preferences and locate "maintenance". Find the "clean print head" option and click on it. Follow the instructions. You might have to do it several times, and that will use a lot of your ink, but it might do the trick!
As for the "printer can't get calibrate", that is refers to your print head. That has nothing to do with your cartridges, as they are just tanks with ink in it. Check this link, might help:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153777&prodTypeId=18972&prodSeriesId=1153777&objectID=c00721373
Mar 08, 2010 | HP Office Equipment & Supplies
How do I deselect "print a diagnostic
you need to calibrate print head, look up to your manual, or try to place the printed test page in the scanner printed side down and hold scan button, after scan, problem should be solved
Jul 10, 2009 | HP Photosmart C3180 All-In-One InkJet...
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
Jul 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
65 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
