Question about GE (PSS26MSRSS) Side by Side Refrigerator
Frost on back wall of freezer, side by side, wont freeze
MODEL GSS22JEMB BB
Serial HA201071
Our Side by side wont freeze on the top two shelves, and the top fridgerator shelves are cool bottom cold, and yes frost buildup in the lower third of the freezer,
I unplugged the freezer this morning almost all the frost is out, wondering what to do next ?
  • 2 more comments
  • Anonymous Dec 20, 2008
    I have the same problem....GE GSS201EMBWW...now food in crisper is starting to freeze as well
  • Heressue Dec 22, 2008
    Noticed that the fridge was cooling too well turned the thermostat up a bit and then the veggie drawer stuff froze...so turned it back down. This morning noticed that the freezer had frost on the back wall but food was thawing. the model number is GSS22JFMA
  • Dorothea Moore
    Dorothea Moore Dec 22, 2008
    Ge Side by side thaws food and spoil all my food.
  • lewilson15 Jan 06, 2009
    We have a GE side by side, too and we have a small leak coming from the freezer side underneath the unit. The freezer has frost collecting on the back wall. The top two shelves of the fridge are not cold & the bottom of the fridge is freezing cold!
    Top Expert:
  • GE Master
  • 5,713 Answers
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Posted on Nov 21, 2017
  • 183 Answers
SOURCE: Frost buildup on ice/water dispenser
Your problem is definatly caused by air entering freezer either from the ice shute flap or door not sealing correctly, try putting a bright torch in frezzer and closing door look for light escaping around edge of door, if you can see the light then change door seal, the fault cannot be anything else. Regards Advisor
Posted on Aug 30, 2007
  • 1073 Answers
SOURCE: Freezer Frost and Too Warm No Ice
replace the defrost heater wr51x10031
Posted on Apr 10, 2008
eagle338
  • 4889 Answers
SOURCE: frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Posted on Sep 02, 2008
  • 172 Answers
SOURCE: freezer has developed some frost in the back
This is a fairly easy problem to solve. First thing you will need to do is defrost the ice on the inside back panel of the freezer. Then remove the back inside freezer panel. You will need to remove your freezer shelves to do this. Once the panel is removed you will need to defrost the coils and surrounding area. Once defrosted you will see your defrost heather on the bottom of the coil and a defrost thermostat on the top of the coil. The defrost thermostat is about the size of a quarter and about 3/4 inch thick. It will be mounted on the coil line. If you have a multi tester you will be able to check continuity through the heater by unpluging it. The defrost thermostat is a bit more tricky to check. It will not read continuity once it is warmer than 50 degrees. The defrost thermostat is a fairly inexpensive part so if your heater is good you may want to just replace the defrost thermostat and see if the problem goes away. The other possibility would be your control board. It is located on the back of the refrigerator and has a metal plate covering it, with sever 1/4 inch screws. This board causes most failures on your model refrigerator. Also a point to remember. This board has had several new upgrades from the one originally installed on your refrigerator. So make sure if you get a new one that you get the listed number I have given you. The older ones are cheaper but they are also not updated and will not function properly on your refrigerator. The following parts listed are the possible parts you will need. Please let me know if you need one and I can ship it to you in about 1-2 days. I do not charge shipping and I give free advise. Thanks and good luck with your frost problem. you can reach us at.
Michael Anderson
Anderson Appliance
(865)945-3808
mca0824@aol.com
defrost thermostat. #WR50X10068 $21.57
defrost heater #WR51X10042 $56.50
control board #WR55X10656 $185.50
Posted on Feb 17, 2009
SOURCE: GE refrigerator side by side-6yrs old
I had this problem...my frige is gss20iejp and it was the defrost heater. Very easy to replace yourself if you're good with a screwdriver. Repair guy wanted 200 bucks. I fixed it myself for 40, but still had to pay the guy 30 bucks to come out. You have to remove everything from your freezer, shelves, etc...
Then take off the back panel.
Coils should be completely frosted up.
Defrost heater is at the bottom. It is metal. Should have 2 screws to remove and Conected by wires on either side, they pull out from the bottom, just tug them. Replace with new defrost heater...your problem will be solved.
If you have any more questions, email me jcoverload@yahoo.com and I'll be glad to help you out. I know how frustrating it can be if you don't have the funds to pay the repair guy and know you can fix it yourself with just a little advice. :)
Posted on May 05, 2009
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Hi, my GE refrigerator has ice developing on the rear wall of the freezer, and things in my crisper drawer are freezing solid,please help!!!!
Unplug refrig. Empty all food from freezer side and remove shelves from freezer. Remove back metal cover from inside freezer. Melt frost with a hair blower. Examine defrost heater at very bottom of the coils you defrosted. If heater coil inside glass tube is broken, replace defrost heater. (note: replacement may look different, but insturctions included with replacement address that) If heater is not broken, replace the small white pencil shapped sensor at the top of the cooling coils.
Dec 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge is cold on the bottom shelves but hot on the top shelve and freezer is not cold enough to freeze
ge has had alot of problems with the computer boards but this sounds like the evap fan isn't working,i need you to answer a few questions for me,first when you open the freezer door do you hear the fan blowing?also from the bottom up remove the second draw or food bin and put your hand on the back wall inside the freezer and tell me if there's like snow or frost on the wall,if so you have a defrost problem,one more thing check the model number,you'll find it in the fridge side,up on the right hand wall near the ceiling
Sep 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer is warm at the top and the crisper is freezing produce
You have a frost blocked evaporator. Unload the freezer, take out the shelves and the back wall, melt the frost with a hair blower, and replace the defrost heater. (located at the bottom of the frosted up coils) Note: the replacement heater may not appear the same as the original, but instructions will be included with new part.
Jul 22, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost Buildup on Top Shelf lower shelves aren't freezing
This link might help you troubleshoot
Freezer Frost inside Symptom Diagnosis Sears PartsDirect
The lucky solution is if the door seal or inner plastic liner need to be placed/repaired (this lets warmer air into the freezer causing frost and poor cooling).
But you can also see from the link that your symptoms could be caused by other electronic related things...more of a challenge to fix...
Helpful?
Good luck on your troubleshooting
Feb 17, 2018 | Frigidaire Freezers
Maytag side by side not defrosting....
You have the signs of a defect in the defrost system which is indicated by the frost buildup on the back wall. This also affects the refrigerator. Call the dealer you purchased it from and request a service tech.
May 01, 2008 | Refrigerators
Ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Nov 28, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
202 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
