Question about RCA F27450 27" TV
ColorTrack wont turn on
Hello i own Colortrak 2000 from 1991 model number F27201GG the problem i am having is that wenever i press power on the tv the tv makes a clicking sound like its about to turn on but then just turns off, also sumtimes i will press the power button and the tv will rapidly turn on and off untill the tv is unpluged sumtimes wen left in the state of turning on and off quickly maybe after 15 min or so it will click on and work fine. If ne1 knows of a fast cheap way to fix it please let me know. Thx
  • 236 Answers
SOURCE: RCA F20539DG
YOU might have a bad relay or a bad solder connection in the relay control circuit. Sounds like a bad solder joint. Stargazer
Posted on Mar 03, 2007
techman
  • 3130 Answers
SOURCE: T.V. DO NOT TURN
There could be a problem in the main power supply or perhaps the standby power supply. To me at a guess i would say there is most likely a bad capacitor in the standby power supply or there is a problem in the switch mode power supply. if you have no electronic troubleshooting skills, play it safe and take the set into a repair shop or replace it. Now a days, a 32" TV set can be had for under 200bucks. Good Luck
Posted on Jun 13, 2007
Shuttle83
  • 1139 Answers
SOURCE: My RCA TV
The shutdown circuit is turning off the tv, you can try to check the IHVT to see if it is shorted out.
You will need a schematic diagram, and a multimeter.
I can tell you from experience that this is a IHVT or a HOT problem, however it is best to troubleshoot it to find out.
Posted on Jan 28, 2008
  • 57 Answers
SOURCE: wont turn on
sounds like the tube is out. could be the transformer but probably not. I don't recommend you try fixing this yourself.
However some rcas are funny: unplug it again and leave it unplugged for about an hour then try again.
Posted on Aug 02, 2008
  • 77 Answers
SOURCE: RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Posted on Feb 24, 2009
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Have a GE universal remote model number 24922-CL3 1349 what codes do I need to use so it will work with my RCA ColorTrak Plus 1996 model tv with model number F27638BC
If your GE remote is universal, you should be able to search all of its codes for one that will work with your RCA TV. If you search is unsuccessful, you may have to try another universal remote. Not all remotes contain all codes.
Sep 29, 2014 | Televison & Video
My xbox wont work with the tv
you need to select the correct input ( source ) from your remote or by using the menu function on the tv
Jun 12, 2013 | Televison & Video
20 inch rca colortrak plus wont turn on.trying to figure out where power relay is on board. any help would be greatly appreciated thanks kris
Dear Kris
You check the out put voltage of SMPS
If OK then check the Horz. out put Transistor / MOSFET
Check the Horz. driver TR.
Apr 28, 2011 | RCA 20" TV
I have a Brookstone large button remote, with no instruction manual. Tring to set it to a RCA colortrack 26" TV. Is there anything i can do?
Hi
Try this:
Automatic Programming
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
5. When the device turns on, press ok to store the code.
Good luck pls rate
Dec 18, 2009 | Televison & Video
I need help finding my code for my TV. Its an RCA Colortrack
To control an RCA TV with a One for All URC-3021, follow these steps:
1) Turn on your TV.
2) On the remote, press the TV key once.
3) Press and hold SET until the LED blinks twice, then release SET.
4) Enter the first four-digit code from the following list:
0047, 1047, 1147, 1247, 1347, 1447, 1547
The LED will blink twice.
If it does not blink twice, go back to step 2 and try the same code again.
5) Aim the remote at the TV and press POWER.
The device should turn off.
If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Hope that helps.
Oct 31, 2009 | One For All URC-3021 Remote Control
Need Remote Control For 1992 RCA TV Set
There should be access to the menu system from the panel controls. Either a menu button or pressing a combination of buttons for a certain period of time to access the menu.
Oct 06, 2017 | RCA F27450 27" TV
No sound
If you are using a cable box try patching the audio from the box to your stereo system. If that does not apply to you, then getting the set fixed or replacement is in order. A colortrack 2000 is like 20+ years old. They don't make them like that anymore., Too bad.
Mar 24, 2008 | Televison & Video
Rca colortrak 2000
what is the chassis number of your set should be a ctc or ptk number?Post hat info and I should be able to give some advice on whats happening with your set.
Feb 18, 2008 | Televison & Video
RCA F27450 27" TV Logo
59 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
