Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
No sound emachines c2685
What external sound card will be compatiable with my C2685 emachine?
  • Leslie May 11, 2010
    pci? any card with compatable drivers will
    Problem Solver:
  • 5 Answers
Go to your control panel and click on sounds and make sure your speakers they are set with a desktop if it is a desktop or if a laptop set it to laptop.
Posted on Jul 10, 2009
Does emachines e627 have a microphone?
this is from the emachines website http://support.gateway.com/emachines/notebook/2009/emachines/eme/eme627/eME627sp2.shtml
Peripheral Subsystem
Integrated webcam, 0.3-megapixel resolution, featuring enhanced technology for low-light environments
5-in-1 card reader , supporting MMC, SD, xD, MS, and MS PRO cards
Built-in microphone
Two USB 2.0 ports
External display (VGA) port
Headphone/speaker/line-out jack
Microphone-in jack
Ethernet (RJ-45) port
DC-in jack for AC adapte
Jun 19, 2011 | Computers & Internet
I need to know where to connect the three seperate 2 pin connectors from the ''power switch'' to the motherboard on my eMachines C2685 desktop computer.
The eMachines C2685 uses an FIC VC37GV motherboard. (First International Computer, Inc.)
http://www.motherboards.org/mobot/motherboards_d/FIC/VC37GV/
Here is the motherboard manual,
http://www.ime.org.uk/pdfs/vc37_vg31_b1_eng.pdf
After you click on the above link, give it up to 30 seconds to download. This is a PDF file.
Barring you cannot download the file, I will state the connections for the Front Panel header on the motherboard.
(Plus state the page to reference to, in case you can download)
View the first link, with the photo of the FIC VC37GV motherboard.
As shown, Processor is at the top, Ram Memory slots are to the right.
The Front Panel header is located at the very bottom right corner.
It is parallel to the outside edge of the motherboard. There are two rows of pins.
(Page 12)
The Front Panel header has 5 pins going across the top, and 4 pins across the bottom.
The top row of pins are numbered Odd.
The bottom row of pins are numbered Evenly.
On the Top row starting on the Right side, going towards the left, the pins are numbered 1, 3, 5, 7, and 9.
On the Bottom row starting on the Right side, going towards the left, the pins are numbered 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HDD LED. (HarDDrive activity LED)
B) Pins 5 and 7 are for the Reset switch
C) Pins 2 and 4 are for a Dual Color Power On LED, if used.
Green goes to Pin 2. Yellow goes to Pin 4.
Otherwise Pin 2 is Positive, ( + ), and Pin 4 is Negative. ( - )
D) Pins 6 and 8 are for the Power On switch.
(PWR1, or SW1)
There is a small 3 pin header, just above the Front Panel header. (Page 12)
This is for a Power LED that has either two wires, or three wires.
The pins are numbered from Right to left.
Pin 1 is for the Power LED, and Pin 2 is for Ground, if using a two wire Power LED. (Not dual color)
Pin 1 is for the Power LED, and Pins 2 and 3 are for Ground (GND), if using a three wire Power LED.
(Page 13)
May 26, 2010 | Computers & Internet
I have a eMachine model c2685.i just need a pic for switch locations in the mother board.where the plugs from the hdd light, power sw, and thepower light plug into the mother.boardplease help
ok i might be able to help there is a motherboard swaping guide on youtube but there should be somthing like this on the motherboard ::::. the one closist to the single should be power ie ::: power: then . then its ::then reset then ::. then it should be hdd led so :then hdd led then:::. and the last is pwr light :<pwr led:<hdd led:<rst:<pwr.< blank hope this helps if it does then please give 5 thumbs up just remeber your looking for the : : : : . then follow my plan
May 15, 2010 | Computers & Internet
When i put my computer in stand-by i get an error telling me that it had to shut down because a problem happend on the system
it means the problem with u r mother board. chaque the temprature of machine. if itis goes high upto 60 degree. refix proccessor fan After clin & paste, it reduce machine temp, reduce the chance of Damage,
Mar 12, 2010 | E-Machines C2685 PC Desktop
What external sound card need my pc model is T2698
How about trying external USB sound card work on almost every model...check it out...
Jul 06, 2009 | E-Machines eMachines Refurbished EMA...
EMachine C2685
check driver, check connection and check the bios configuration
May 12, 2008 | Computers & Internet
No sound in speakers emachine
External or interal speakers?
Check control panel under sound to see if mute is checked on sound card.
Check system icon control panel, hardware, device manager to see if sound card is installed correctly? ! means not installed properly.
Apr 13, 2008 | E-Machines emachines (emachinees) CD-ROM...
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
313 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
