Red oil light appears and rattle noise what is the cause
SOURCE: oil change light
Turn the key on. Observe the odometer. Is "ODO" displayed? If not, push the trip meter button until "ODO" is displayed, with the total mileage travelled shown.
Turn the key off.
Push & HOLD the trip reset button until advised to release it.
Turn the key to "ON" (do not start engine)
Observe the ODO display.
You should see 5 dashes, then 4, then 3, then 2, then one, and finally, five zeros.
The original mileage that you observed should be redisplayed.
Release the trip reset button.
The proceedure is now complete.
SOURCE: where is the oil filter on the 2009 Toyota corolla
I assume that you have a 1.8 engine. The oil filter is in a round metal housing under the engine; you have to remove the housing to access the cartridge type oil filter; the 1.8s do not have a "spin-on" filter.
SOURCE: Orange check engine light fpr 2005 toyota corolla
An orange check engine light means there is an electronic failure in the engine control system. It could be anything from a loose fuel cap, to a bad sensor on the engine. It is not an emergency, but you should get it checked out. A red engine light is an emergency and requires you to immediately stop the car. Yellow is a warning.
SOURCE: Reset the maintenance required light on my 2008 toyota corolla
OK ON YOUR SPEEDOMETER, THERES TRIP A, TRIP B, AND THE REGULAR ODMO... U NEED TO PUT IT ON TRIP A (WITH THE KEY OFF) ONCE U GET IN ON TRIP A, PUSH AND HOLD THE BUTTON DOWN,WHILE HOLDING BUTTON DOWN TURN KEY ON, YOU WILL SEE LINES POP UP ON THE ODOMETER, (WHERE THE MILES ARE DISPLAYED) THEY WILL GO OUT ONE BY ONE, ONCE IT STATES 0 YOU ARE GOOD TO GO.. GOOD LUCK AND THANK YOU FOR USE FIXYA.COM..KEITH..
SOURCE: my toyota corolla is having a knocking sound after
YOUR MAIN BEARINGS IS WORN OUT.IF MAIN BEARING IS WORN OUT ENGINE CANT BUILD UP OIL PRESSURE.YOUR BEARING CLEARANCE AND CRANK TOO EXCESSIVE.
