Question about Whirlpool LGR7646E Dryer
NO HEAT DRYER
My dryer stopped heating but will still run.It's an old dryer whirlpool model LFE 5701.I flipped the breaker. removed the back cleaned out all lint- not any more lint then you would expect.I noticed the heating element, so with back off i reconnected the power and checked for a glow since I do not have a ohm meter.There was no glow so I assume it is the element itself? Is there anything else that can cause the element not to glow that I need to check for?
  • Anonymous Apr 09, 2009
    The dryer turns on and tumbles, but no heat is evident
  • 96 Answers
Alot of dryers have temp overload fuse
Posted on Dec 21, 2008
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
I flipped the breaker in my fuse box to my dryer off and back on while the dryer was running. now the dryer wont come back on. what could be the problem and is it easy to fix?
if the unit was working fine before you flipped the breaker off then i would say you have a bad breaker... it is possible for only half the breaker to fail and you would still have a light and possible even tumble on dryer but no heat.... turn breaker off again and snap back on may require a few trys and it may require replacement of breaker...obviously the correct way to test would be with a volt meter (ac current) and test at your dryer where it connects are you getting 220- 247 volts on the 2 outside terminal connections... if not your breaker or plug has failed.... good luck to you
Jan 19, 2011 | Whirlpool WED5300S Electric Dryer
Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Sep 21, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
No heat
Try testing the voltage across both fuses. The time you swapped fuses, and the motor ran without heat indicates to me that one of your hot leads is not getting voltage. On a three wire system, you should have two 110v leads and a common. Make sure that the cord is connected properly, and the same for the receptacle that you plug into. Test the receptacle as well for proper voltage and a good common ground.
Hope that this helps. Please repost if necessary.....Operators are standing by......!
Regards, --W/D--
Jul 18, 2009 | Whirlpool Dryers
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
236 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
