Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I don't know a thing about it.
I recieved this device from school w/o instructions. I don't know how to save anything to my flash drive. I have A, C, and D drives in the my computer. How and where do I save documents to my flash disk
    Novelist:
  • 93 Answers
When you insert the flash drive into a USB port, the system will (okay, should) recognize it as a "removable" drive. It will assign a drive letter to it, which you can treat as a regular hard drive.
So, plug it in, then open My Computer, and you should see it there. Save to it, delete from it, whatever you want. If your system is not recognizing it (XP and Vista should do so, automatically), then you may have a flash drive that requires a driver (typically, SanDisk units do not).
Cheers
Nick
Posted on Dec 20, 2008
How cn I knw if my study material is available and after how long can I receive my study material
This site tries to help people by answering (most technical) questions. We don's provide anything else. If you want service for anything, goto the site from the school you ordered the material.
We don't even know what school you are referring to, we don't even know what you are expecting.
Jul 12, 2014 | GPS
Need instruction manual don't know how to use
An example on how to download and save to an External Hard Drive and copy and paste to an External Hard Drive Click start all programs accessories open windows explorer navigate to your data
Right click on the data select copy navigate back to the External Drive.
or right click on the data select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet.
Once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into your External Drive or a folder in my documents or another device or a usb device
if you need more help with this post a reply Hope this helps
Oct 27, 2011 | Kingston 2PK 4GB USB 20 DATATRAVELERI GEN...
I have a Iomga 2.5 eGO Portable Hard Drive that can't be mounted in a windows 7 or windows XP laptop when USB cable is connected, The laptop detects a OEM Ext Hard Disk USB Device and drive recieve...
The first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Sep 02, 2011 | Iomega Computers & Internet
I could n't access my files in my pendrive JF V30
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Sep 09, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
LOST MY INSTRUCTION SHEET FOR SANDISK CRUZER 3 GB FLASH CARD
check out this link , and download the drivers or manual http://www.sandisk.com/sandisk-support/driver-download-wizard
Jul 07, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My PC will not recognize PNY USB 2.0 4G drive. It is not in My Computer folder either.
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes
USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a
USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all
USB cables are equal even though they should be)
3. Do not connect through an external
USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the
USB "Safely Remove Hardware" option. If you don’t do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to check the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. Ensure that you have set removable drives for "quick removal" or that you use the "Safely Remove Hardware" option often shown on the lower toolbar. It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! And knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click of Death"
Hope this gives you the information you need
Apr 14, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
How to unlock a web site in school and i want to know because i know u got the answer for me
Hi and welcome to Fixyah,
What did you mean that you how to unlocked the website to your School? Did you mean all the site is blocked? well simple go ahead and download U95.exe and then save it to your flash drive. From your flash drive connect that to the computer on your school and from there open and double click U95. There is internet explorer open.From there there you can open all the block site.
Happy surfing.
Mar 11, 2010 | HP PSC 2210 All-In-One InkJet Printer
Bought an Iomega external hardrive and saved all my things from my previous job on it. Now, I am opening everything at my new job and although I can open it, I can not saved or edit or delete anything
Hello:
When you open My Computer is this new external drive recognized? Does it happen to say Disconnected Drive?
At work, does your IT department restrict you from adding any perripherial devices to your computer?
If this does not help, please let me know.
Joe
Apr 20, 2009 | Iomega 33089 250 GB Hard Drive
I cannot use my printer right now, and I have a composition assignement stored in a file on my Dell and want to transfer onto my flashdrive to take and print out at school with their printer. Please give...
Double click the file you want to move. When the progam opens the document, Choose"Save As" from the File Menu. When the dialog box opens, navigate to you flash drive. Something like (E):Kingston the choose "Save" Now a copy of your file will be on your Kingston Flash drive.
Double check by opening the flash drive and look for the file.
Feb 01, 2009 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
62 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
