Question about Epson Stylus Photo R220 InkJet Printer
Ink and paper light are blinking and unable to access cartledge
I have the same problem you, Were you able to fix it? thanks
  • 159 Answers
Had the same problem. (this is a work around)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
  • Bill Miller
    Bill Miller Feb 14, 2009
    Sorry try this 1st. then do all the other stuff.
    this is how to reset it try it 1st.
    • ress and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen
      saying counter is reset and to turn the printer off. The R200 and
      others don’t have a screen so just wait until the 10 seconds is up.
    • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
Epson Stylus Photo 2200
Hi there. I managed to find an excellent resource that should help you solve your problem. Try the suggestions given here http://www.fixyourownprinter.com/forums/inkjet/24337 i would start with "holding both paper and ink buttons then powering on untill the paper light flashes and then holding the ink button for 10 secs" Let me know if this helped. D.
Aug 02, 2007 | Epson Stylus 2200 InkJet Photo Printer
Hp deskjet D4155...Both power and arrow lights are blinking and I have tryed turning it off and un-plugging the printer multiple times, Every time is comes on, they both are still blinking. Please help....
Please remove the ink cartridges, unplug the power cord. You may also remove the paper from the paper tray. Now, try inserting the cartridge as well.. after about 20 seconds, plug in the power..
put in the paper, and ensure that you have inserted the paper properly. Then insert the ink cartridge. This should resolve the problem.
But if the light is still blinking , try by replacing the ink cartridge.
Aug 12, 2010 | HP Deskjet D4160 InkJet Photo Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
For Canon mp210. Error light blinks. Either E22 or E2
Hi there
This is a Carriage error take a good look at the carriage that the inks are in and see if they are sitting ok and also do the next incise there some thing there stopping it from moving.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 07, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Epson R230 ink & Paper Lamp Blinking
Blinking alternately or not? If alternately, need to reset waste ink counter. SSC can fix it. But if not, it's general error. It's may be carrriage error.
Aug 02, 2009 | Epson Stylus Photo R200 InkJet Printer
UNABLE TO PRINT
Most likely, you have paper jammed inside the printer in the far left or far right of the printer. It also is possible that the encoder strip may have come off the printhead.
the paper jam you could probably fix yourself by pull out the paper, the encoder will need to be sent it for repair.
thanks adi
Apr 23, 2009 | Brother MFC 210C All-In-One InkJet Printer
Blinking lights
The pads do need to be replaced. It is not as simple like the 1280. it does need to be taken into an authorized service center.
we are, and located in southern california.
I have taken the pads out and 95% of the time are all completely soaked. you can do what you did, but you will not get the full life out of a pad.
thanks
Apr 17, 2009 | Epson Stylus 1400 InkJet Photo Printer
All 4 lights blinking
I cannot get ink printer out as it stuck in Epson Stylus color 760. I have been clean and extract waste leak ink away. The light is still blink. Sigh
Apr 09, 2009 | Epson Stylus Color 760 InkJet Printer
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
