Michelle Brewer Posted on Aug 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to i get the exponents to multipy out?
I can put in the calculator 2 to the 20th power, but if i want that simplified by multiplying all the way out.....How do i do that?
k24674
Level 3:
  • DateXX Master 8,093 Answers
  • Posted on Feb 04, 2014
k24674
DateXX Master
Level 3:
Answers
8093
Questions
0
Helped
4675615
Points
21596
You do not have to do anything special. Just enter what you want and press EXE. Depending on the display type chosen you get
2^20 EXE gives 1048576.000.. for floating point, 1.04857600 *10^06 for Scientific or the same (particular case here) 1.04857600 *10^06 for Engineering. The number of digits after the decimal mark depends on the number of decimal digits chosen in your setup.
What is most common power problem?
If by power, you mean exponents, there are several rules.
Multiplication with the same base - add the exponents
Division with the same base - subtract the exponents
Exponent to an exponent - multiply the exponents
Negative exponent - 1 over the same number to the positive exponent
Zero exponent - anything to the exponent 0 is 1
Good luck,
Paul
How do you simplify the exponent on the calculator?
I assume 13m/2 is the radius of the sphere and you are trying to calculate the volume of the sphere.
The first thing we have to think of is BEDMAS, the order of operations, as some calculators do them correctly, while others do not. Let's be safe and do the BEDMAS manually so we know we will get the correct answer.
B - brackets - enter 13/2 in the calculator - hit enter
E - exponents - with the answer from the first line in the calculator, use the hat key (^) or the y to the x key to raise this to the third power (exponent 3).
M - multiply - with the answer from the line above, multiply this by pi or use what you are instructed to use or use 3.14159, then multiply by 4 and divide by 3.
You should have your answer.
Good luck.
Paul
1helpful
What is factoring and give the examples
Quick-Start Guide When you enter an expression into the calculator, the calculator will simplify the expression by expanding multiplication and combining like terms. At this point the calculator will attempt to factor the expression by dividing a G C F, and identifying a difference between two squares, or factorable trinomials. Use the following rules to enter expressions into the calculator. Variables Any lowercase letter may be used as a variable. Exponents Exponents are supported on variables using the ^ (caret) symbol. For example, to express x 2, enter x ^ 2. Note: exponents must be positive integers, no negatives, decimals, or variables. Exponents may not currently be placed on numbers, brackets, or parentheses. Parentheses and Brackets Parentheses ( ) and brackets [ ] may be used to group terms as in a standard expression. Multiplication, Addition, and Subtraction For addition and subtraction, use the standard + and - symbols respectively. For multiplication, use the * symbol. A * symbol is optional when multiplying a number by a variable. For instance: 2 * x can also be entered as 2x. Similarly, 2 * ( x + 5 ) can also be entered as 2 ( x + 5 ) ; 2 x * ( 5 ) can be entered as 2 x ( 5 ). The * is also optional when multiplying parentheses, example: ( x + 1 ) ( x - 1 ). Order of Operations The calculator follows the standard order of operations taught by most algebra books - Parentheses, Exponents, Multiplication and Division, Addition and Subtraction. The only exception is that division is not currently supported; attempts to use the / symbol will result in an error. Division, Square Root, Radi cals, Fractions Division, square root, radi cals, and fractions are not supported at this time. A future release will add this functionality.
that's all I can say basically I learned it this way.
I am trying to calculate powers with my Texas Instruments BA ii plus, but big powers such as ^360 gives me an error msg. How can I solve this problem? Thanks!
Break the problem up into smaller pieces.
There's a limit to how big a number the calculator can represent. Numbers as large as 10 times 10 to the 100 simply can't fit into the calculator. For really large numbers, calculate the mantissa and the exponent (power) separately.
For example, to calculate 2^360, first calculate 2^300: press 2 ^ 3 0 0 = and see 2.037036*10^90. Divide by 10^90 (and remember the 90): / 1 0 y^x 9 0 = and see 2.04. Multiply by 2^60: * 2 ^ 6 0 = and see 2.348543*10^18. Multiply that by the 10^90 we took out earlier by adding exponents and write down 2.348543*10^108. That number is too large to fit into the calculator but we got it by calculating the 2.348543 and the 108 separately.
1helpful
Just got a SHARP EL-531X, it won't do simple calculations with scientific notation, It keep saying
To enter the power of 10 with exponent use the Exp key followed by the exponent. If the exponent is negative, you must use the negation key (-) not the - key (for subtraction).
When you press the Exp key you do not type in the 10.
(4/3)pie x 3 to the 3 power? how can i press it my Texas Instruments TI-30 XIIS Calculator
((4/3)pi3X)^3. put 4/3 within its own parenthesis and multiply it by the symbol for pi (2nd,^), imput 3x and put that entire parenthesis to the exponent (^) of 3
Try to multiply (20x10-9) (1x10-9)
If you use the exponent rules you do not need to use a
calculator for this particular case. Anyway to enter power of 10 exponents you use the [EE] key. See screen capture below.
20 [EE] (+ -)9 [X] 1[EE] (+ -) 9
How do I add Exponents on my T1-30xa calculater
There is a rule of Algebra, that says
(a^m)[x] (a^n) = a^(m+n)
a is the base of the power, n, and m are the exponents. As you can see, multiplying two powers of the same base is equal to the power of the (common) base with the sum of the exponents.
If that is what you had in mind, the calculator uses the rule correctly and no intervention from you is necessary.
If you enter (2^4)[x](2^6), the calculator will give 1024, which is 2^10.
I may be wrong, but what you call add exponents refers really to performing addition where addends (the terms you add) are arbitrary powers, such as
2^7 + (5.5^3) - (1/3)^4
Once you enter a power term, the calculator calculates it and the result is now just a number. It can be added, subtracted, multiplied
For the exemple above
2 [Y to the x] 7 + (5.5)[Y to the x] 3 -(1/3) [Y to the x] 4 [=] yields 294.3626543
For the cube of 5.5 you can use the key combination [2nd][X^3]
Hope it helps.
Poisson
Hello
To raise a number to any power you use the [^] caret key or on some calculators the [x^y] (x raised to exponent y)
20^(4) =160000
20 to the power of negative 3
20[^] 3 [(-) or +/-] ENTER gives 1.25x10^(-4) = 0.000125 (-) is the small minus sign.
If that gives you a syntax error
20[^] [(-) or +/-] 3[ENTER] = 0.000125
27 [^] (1/3] represents the cube root of 27 which is 3.
Hope it helps.
Top DateXX Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a DateXX Office Equipment and Supply Expert? Answer questions, earn points and help others
