Question about Coby DVD-958 Theater System
Dvd problem How do you hook up the dvd to the tv with the av cable you provided (3 one end & 3 other. Your small enclosed Coby quick start guide shows only one YELLOW av cable. Is that all you need, one....? We get the dvd small sign on the tv , but when we insert a dvd, we get scrolling and distorted picture. Our old dvd player up and died, so I know, while using the tv remote, how to get to dvd mode but like I said scrolling. Please help.
This cable is called a composite cable. You will use the yellow for video and the red and white for audio. your best bet would be to us an S video cable if your tv is set up for that. If so then you would use the S video and only the red and white for the audio because S video does not carry audio it only carries a video signal
Posted on Jan 09, 2009
Tf d Ihave a tf dvd7100 I am trying to hook it up to my tv to plac a movie cd
HI,
Before connecting the the DVD to your TV First of all you have to the audio out put of your for the do the following using the setup menu.
Press SETUP button of of the DVD player to show "setup" menu. Select the audio setup the select the digital out then change to OFF from SPIDF/RAW.
Here i have added a picture which shows how to hookup the dvd player to a TV. Its for the same model that you have .
to make the connection you need two codes
1. 3.5mm stereo to two RCA (for audio)
2. 3.5mm mono to single RCA(for video)
connect the first cord to inoptical/audio and second one to video output of the dvd player.
connect the cable which comes from the video out out of dvd to the video input (yellow) of your TV. then connect the cable which comes from the inoptical/audio of the dvd player to the audio input of the TV (red and white ).
You have to select the input of your TV by pressing the AV/ source selection on the remote of the TV. check where you made the connection on the tv AV 1 or AV 2. then select the corresponding input. hope you will get it worked.
Also Added the image of the cable that you need to make the connections.
25383850-eev1v0sv1zwox43luwgxtns5-4-5.jpg 3.5mm stereo to two RCA (for audio)
Electronics Equipment Repair Center
Jan 25, 2015 | Coby TF-DVD7107 Portable DVD Player
My DVD 958 not showing with the hdmi cable through the television
You first should hook the device up with AV cables, after you uses AV cables , you will get a picture, once you get a picture, you need to go into the setup menu and turn on HDMI, once you do this, then you can switch to the HDMI cable.
Jan 29, 2013 | Coby DVD-958 Theater System
How to hook up my dvd player to the t.v.
Hello
You haven't given any specifications about your tV here. Anyway, you can hook up the DVD player to TV using an AV cable. The AV cable will have three cables together with two RCA connections at each end of each cable. Look at the colour of them. Usually one Red, one White and an other will be yellow. Just connect them to the sockets of both DVD and TV accordingily, and switch ON both devices, select the tV input to AV1 or AV2. If all the connections are correct, you will see the logo of Mitsubishi on TV screen. This is the picture of AV cable. OK.
Nov 08, 2011 | Mitsubishi DD-8030 DVD Player
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Can't find AV cables
try amazon.com or newegg.com and lastly ebay
Sep 03, 2009 | Televison & Video
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Do not know what to hook subwoofer to - TV, DVR?
This should all be described (at least in Chinglish) in a user guide.
For sure, two of the threesome cable are right (red) channel and left (white) channel. The remaining one probably for center or rear.  Mostly all of the different pieces should have color-coded in- and output jacks.
Look at the connector legends printed on your devices, they should have markings such as "line" both in- & out- and you will find corresponding markings on each.
You would need the 'out' connections from either the DVD and TV to end up on the 'in' connectors of the Coby main unit, presumably the woofer cabinet since these mostly house the electronics; i.e. power supply and amplifier.
Sep 06, 2008 | Coby CSP-94 Speaker
Quick Start Guide for Durabrand DVD 1002
place one end of the scartlead into av 1 or av 2  on back of  tv,
other end of scart to dvd player .
plug dvd player  in,and turn on dvd player it should detect the dvd and turn to dvd channel automatic .
Oct 23, 2007 | Durabrand DVD-1002 DVD Player
Coby DVD-958 Theater System Logo
194 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
